Re: [mpich-discuss] man mpich-3.0.4
Why is any of that required? I was able to install the man pages by hand with "/bin/cp -r". Why do I need doctext for "make mandoc" to work? Shouldn't "make mandoc" just do that? Jeff On Sun, Sep 29, 2013 at 5:17 PM, Ken Raffenetti <[email protected]> wrote:
You need to set that environment variable relative to your doctext installation. The default location is /usr/local/share/doctext.
----- Original Message -----
From: "Jeff Hammond" <[email protected]> To: [email protected] Sent: Sunday, September 29, 2013 1:51:37 PM Subject: Re: [mpich-discuss] man mpich-3.0.4
The target is "make mandoc". And yes, if you don't specify --manpage, it'll put it in your prefix path by default. You only need to provide the additional --manpage information if you want to install it in a different location. You never have to copy it manually.
What does this mean?
Jeffs-MacBook-Pro:build-clang jhammond$ make mandoc test -d /Users/jhammond/eclipse/MPICH/git/build-clang/man/man1 || mkdir -p /Users/jhammond/eclipse/MPICH/git/build-clang/man/man1 test -d /Users/jhammond/eclipse/MPICH/git/build-clang/man/man3 || mkdir -p /Users/jhammond/eclipse/MPICH/git/build-clang/man/man3 make mandoc-local DOCTEXTMAN src/mpi/attr/attr_delete.man-phony Error: Error reading nroff.def in path .:NONE/share or TEXTFILTER_PATH environment variable:-1 make[1]: *** [src/mpi/attr/attr_delete.man-phony] Error 1 make: *** [mandoc] Error 2
Jeff
-- Jeff Hammond [email protected] _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
