Re: [mpich-discuss] Parallel test hanging with mpich on rhel7
On 02/06/2014 09:10 PM, Balaji, Pavan wrote:
Thanks. That�s very useful analysis. Would you be willing to try the attached patch to see if it solves this issue?
� Pavan
Well, it seems to prevent a hang (although I'm also updating from 3.0.4 to 3.1rc3 so not sure what is all changing here), but it does not run: ============================ Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(467)..............: MPID_Init(177).....................: channel initialization failed MPIDI_CH3_Init(70).................: MPID_nem_init(319).................: MPID_nem_tcp_init(171).............: MPID_nem_tcp_get_business_card(418): MPID_nem_tcp_init(377).............: gethostbyname failed, i-00001ff8 (errno 1) Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(467)..............: MPID_Init(177).....................: channel initialization failed MPIDI_CH3_Init(70).................: MPID_nem_init(319).................: MPID_nem_tcp_init(171).............: MPID_nem_tcp_get_business_card(418): MPID_nem_tcp_init(377).............: gethostbyname failed, i-00001ff8 (errno 1) =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 19673 RUNNING AT i-00001ff8 = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== -- Orion Poplawski Technical Manager 303-415-9701 x222 NWRA/CoRA Division FAX: 303-415-9702 3380 Mitchell Lane [email protected] Boulder, CO 80301 http://www.cora.nwra.com
participants (1)
Orion Poplawski
