Re: [mpich-discuss] low performance in an asynchronous, mixed MPI/pthreads app
On Mon, Jan 7, 2013 at 10:44 PM, Geoffrey Irving <[email protected]> wrote:
On Mon, Jan 7, 2013 at 10:53 AM, Dave Goodell <[email protected]> wrote:
On Jan 6, 2013, at 8:57 PM CST, Geoffrey Irving wrote:
We're seeing much lower performance than expected, and are trying to understand why. Here is a visualization of a 96 core test run using 16 ranks with 6 threads per core (4 Hopper nodes):
http://naml.us/random/pentago/history-random17.png
1. All messages are sent using MPI_Isend, but Isend sometimes takes a very long time to return even for tiny (8 byte) messages. For example, the light blue "wakeup" messages are sent from a worker thread to the master communication thread to indicate that computation is complete, breaking the communication thread out of an MPI_Waitsome call (using MPI_THREAD_MULTIPLE). Some of the input request Isends also take a long time, and these are also 8 bytes. What would cause MPI_Isend to take a long time to return, both for small messages (wakeups and input requests) and for large messages (input responses and output sends)?
One possibility is because MPICH-nemesis (on which Cray's MPI for XE6 is based) does not have any fine-grained parallelism in the library. So in order for an Isend-ing thread to properly enter the MPI library, it must queue on a mutex until the thread which is currently occupying the progress engine decides to yield. In nemesis by default this is 10 iterations of {polling shared memory then the network module}, although Cray may have decided to tweak this number (I have not seen their source). So overly long netmod polling times could contribute to this delay.
This design is simplistic, and we aren't especially happy with it, but so far we've found it to be very difficult to retrofit finer-grained parallelism into the existing nemesis codebase. My personal opinion is that a real fix will require a substantial rewrite of a large part of the lower level code.
If I'm understanding your questions/explanations correctly, then this is likely related to issues 2 & 3 as well, possibly 4.
Some things that might contribute to the problem:
1. Since the 92K input responses are sent in response to 8 byte request messages, I can prepost all matching Irecvs. However, output messages arrive unexpectedly, so the best I can do is post a few wildcard Irecvs (MPI_ANY_SOURCE, MPI_ANY_TAG on the output message communicator). Jeff thought wildcard Irecvs might not be good enough to hit the fast path. Moreover, output messages are not compressed, so most are 262K. I didn't compress them historically because compression isn't all that fast (I'm using Google's Snappy plus domain specific preconditioning), but that may be a good experiment to run.
Preposted any_source+any_tag irecvs should be on the fast-enough path. The size is large enough that it might be tipping you over into a rendezvous instead of eager protocol, but only Cray can answer that for sure. I probably wouldn't pursue compression as a first next step.
And you're correct: at least in the current setup output compression slows things down, probably in part because it results in more intrarank messages (I had already started implementing this experiment before I got your email).
2. I don't know how to visualize instantaneous bandwidth, even though I have start and end times for all large messages (start and end of Isend, Irecv request completion time). It's possible the problem is bad network load balancing. I'm happy to whip up a plot if anyone has suggestions as to what to draw.
I'm not sure what the goal is here. 262 KiB messages don't strike me as large enough to worry much about bandwidth on a modern Cray machine. Latencies seem like a more useful metric still, esp. if you aren't seeing much variation as a function of message size.
3. Waking a communication thread out of an MPI_Waitsome is somewhat of a hack. It's the only time the worker threads touch MPI; otherwise I could use MPI_THREAD_FUNNELED. However, the only alternative I know is for the communication thread to poll on MPI_Testsome and check for thread completion in between. Might that be better (it's an easy experiment to run)?
Frankly, it might, because of the aforementioned design. What non-MPI mechanism for inter-thread signaling are you planning on using?
All the thread signalling is via pthread spinlocks and the occasional lockless spin when I can get away with it. In the MPI_Testsome case the communication thread would check a flag for inter-thread messages without grabbing a lock, then grab a spinlock and recheck.
I'll implement this tomorrow and see how it fares.
Polling on MPI_Testsome and spinlocks and using MPI_THREAD_FUNNELED does significantly better than bare MPI_THREAD_MULTIPLE, and a little better than asynchronous progress mode: funneled, 1 comm thread and 5 workers: 157.0734 s multiple, 1 comm thread and 5 workers: 208.9402 s asynchronous progress, 1 progress thread, 1 comm thread, 4 workers: 169.9694 s Here are a few history trace screenshots (zooming in). The worker thread stalls is wakeup are gone of course, but otherwise it is similar. http://naml.us/random/pentago/history-funnel-random17.png http://naml.us/random/pentago/history-funnel-random17-1.png http://naml.us/random/pentago/history-funnel-random17-2.png I'm going to try on BlueGene next to see if the performance is similar. Geoffrey
participants (1)
Geoffrey Irving
