--enable-strictmpi not respected
Hi there, I think I've discovered an issue with the mpich-3.2 MPI tests not respecting the --enable-strictmpi flag passed in to the configure script. I'm building the mpich tests against OpenMPI. The full configure line I'm using is given below: export MPI_PREFIX=/home/build/OMPI ./configure --enable-strictmpi --disable-cxx --disable-fortran --prefix=$MPI_PREFIX CC=$MPI_PREFIX/bin/mpicc CFLAGS="-I$MPI_PREFIX/include" LDFLAGS="-L$MPI_PREFIX/lib64" When running "make" in the mpich-3.2/test/mpi directory, the following error is generated: Making all in ft make[1]: Entering directory `/root/mpich-3.2/test/mpi/ft' CCLD failure_ack failure_ack.o: In function `main': failure_ack.c:(.text+0x160): undefined reference to `MPIX_Comm_failure_ack' failure_ack.c:(.text+0x1e3): undefined reference to `MPIX_Comm_failure_get_acked' failure_ack.c:(.text+0x444): undefined reference to `MPIX_Comm_failure_get_acked' collect2: error: ld returned 1 exit status make[1]: *** [failure_ack] Error 1 make[1]: Leaving directory `/root/mpich-3.2/test/mpi/ft' make: *** [all-recursive] Error 1 The compiler is picking up the declaration of MPIX_* from the mpich-3.2/src/include directory, but obviously the OpenMPI libs won't have definitions for those. However, the fact that it's searching for these symbols at all seems to indicate that the --enable-strictmpi option isn't being respected since the MPIX_* functions are nonstandard. Any insight into this would be greatly appreciated! Thanks, Levi Dettwyler Intel Corporation [email protected] _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Dettwyler, Levi E
