Re: [mpich-discuss] Overlapping non-blocking collectives leads to deadlock
Hi Mark, I agree with Guiseppe. This is an issue in your code. You can use different communicators (e.g., duplicates of comm-world) if you want to concurrently execute collective communication by different threads. - Joachim On 11/18/19 5:25 PM, Mark Davis via discuss wrote:
Hi Giuseppe, thank you for the fast response -- that clarifies things for me.
On Mon, Nov 18, 2019 at 10:39 AM Congiu, Giuseppe via discuss <[email protected]> wrote:
Hello Mark,
I don’t think that is a bug in MPICH, it’s a bug in your code. The MPI standard requires that collectives (non-blocking ones are no exception) must be invoked in the same order in all processes. If T0 in process 0 runs first and T1 in process 1 runs first you have a mismatch and a resulting deadlock.
—Giuseppe
On Nov 18, 2019, at 8:27 AM, Mark Davis via discuss <[email protected]> wrote:
I realized something else relevant: I mentioned above that this deadlock occurs sometimes but not all of the time; I think I've narrowed down when it happens. Here's the above example with thread IDs annotated in:
PROCESS 0 (root for ireduce and ibcast): // T0 is always the thread that calls MPI functions T0: MPI_Ireduce(..., &req) T0: MPI_Wait(&req); <-- blocking here ... T0: MPI_Ibcast(..., &req2); T0: MPI_Wait(&req2);
PROCESS 1 (non-root for ireduce and ibcast): // T0 is the root for the reduce T0: MPI_Ireduce(..., &req) T0:MPI_Wait(&req); ... // T1 is the root for the bcast T1: MPI_Ibcast(..., &req2); T1: MPI_Wait(&req2); <-- blocking here
Note that the non-root process has two different threads, T0 and T1, and T0 does the Ireduce and T1 does the bcast. I believe the T0 call to MPI_Ireduce is concurrent with the T1 call to MPI_Ibcast (both as non-roots).
So, I believe the question is: is it legal in MPI to have two threads in a given MPI process call different non-blocking collectives (e.g., reduce and bcast) concurrently with MPI_THREAD_MULTIPLE enabled?
Thank you
On Mon, Nov 18, 2019 at 10:05 AM Mark Davis <[email protected]> wrote:
Hello, I'm experimenting with non-blocking collectives using MPICH in a multithreaded C++ program (with MPI_THREAD_MULTIPLE initialization).
I'm currently doing a non-blocking reduce followed by a non-blocking broadcast (I realize I can just use an allreduce but for my experiment, I need to serialize these operations). I was able to produce this bug with only two MPI processes. I see in gdb that the root process is stuck trying to execute the MPI_Ireduce in cases where the non-root process does the MPI_Ireduce and gets to the MPI_Ibcast quickly. That is, process 0 (root) isn't able to complete the MPI_Ireduce wait while process 1 is stuck in the MPI_Ibcast wait.
PROCESS 0 (root for ireduce and ibcast): MPI_Ireduce(..., &req) MPI_Wait(&req); <-- blocking here ... MPI_Ibcast(..., &req2); MPI_Wait(&req2);
PROCESS 1 (non-root for ireduce and ibcast): MPI_Ireduce(..., &req) MPI_Wait(&req); ... MPI_Ibcast(..., &req2); MPI_Wait(&req2); <-- blocking here
Much of the time, the program deadlocks as shown above; sometimes this works fine, though, perhaps due to subtle timing differences. I mentioned above that this is a multithreaded program. I'm able to produce the issue with two threads with two MPI procs. The other threads are not calling MPI functions -- they are helping with other computation. I've verified that I don't have any TSAN or ASAN errors in this program. However, when I only have one thread per process, I don't have this issue. I think there's a decent chance, though, that this has to do with timing differences as opposed to changing anything with the MPI calls. I have verified that only one thread per process is calling the MPI routines in the multithreaded case.
When I change the MPI_Ireduce to a blocking MPI_Reduce and I keep the MPI_Ibcast non-blocking, the program runs fine. Only when BOTH MPI_Ireduce and MPI_Ibcast happen serially do I see this deadlock (again, some of the time).
Unfortunately, this program is part of a very large system and it's not straightforward to give a fully working example. So, I'm just looking for any ideas anyone has for what sort of thing may be happening, any information that may be helpful about how two coincident non-blocking requests could interact with each other, etc.
Also, if anyone has tips on how to debug this sort of thing in gdb that would be helpful. For example, are there ways to introspect the MPI_Request object, etc.?
Thanks
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Dipl.-Inf. Joachim Protze IT Center Group: High Performance Computing Division: Computational Science and Engineering RWTH Aachen University Seffenter Weg 23 D 52074 Aachen (Germany) Tel: +49 241 80- 24765 Fax: +49 241 80-624765 [email protected] www.itc.rwth-aachen.de
participants (1)
Joachim Protze
