Re: [mpich-discuss] Q: Why doesn't "use mpi, only : mpi_bcast" (or similar) work in MPICH?
MPICH’s `use mpi` module does not define function interfaces. Functions such as `MPI_Send` and `MPI_Bcast` are directly linked to the C symbols. Fortran 90 used to have very poor support for “choice buffers”, which probably resulted in the decision not to define the function interface in our legacy “use mpi” module. We recommend to try “use mpi_f08” instead. The `mpi_f08` interface has the full interface defined and adopts the C interoperability features. -- Hui Zhou From: Brian Dobbins via discuss <[email protected]> Date: Tuesday, June 1, 2021 at 7:53 PM To: [email protected] <[email protected]> Cc: Brian Dobbins <[email protected]> Subject: [mpich-discuss] Q: Why doesn't "use mpi, only : mpi_bcast" (or similar) work in MPICH? Hi all, I figure this is one of those things in the standard, but I figured I'd get a better explanation asking here than digging through that myself. Long story short, if I try the following code: program foo use mpi, only: mpi_bcast end program foo ... This fails to compile in MPICH (3.4.2, at least), IntelMPI and MVAPICH, but does work on OpenMPI and SGI MPT, at least on systems I've tried. Replacing the 'use, only' with just a 'use' directive works fine. And MPI_BCAST is just an example here; things like 'MPI_Finalize' and 'MPI_Integer' appear to be in the module, but MPI_Send also fails. Is this a scenario where the standard doesn't support this, but OpenMPI and MPT do it as a matter of convenience vs strict adherence found in the MPICH-based libraries? Or am I missing some simple issue? Any insight would be greatly appreciated! Thanks, - Brian
participants (1)
Zhou, Hui
