Re: [mpich-discuss] per-object build issue
No problem. Anyone from ANL brave enough to patch this in? I’m not sure what it will break, I definitely didn’t test it extensively across all threading types. -C On May 29, 2014, at 12:03 PM, Greenberg, Hugh N <[email protected]> wrote:
Charles,
It seems to work. Thanks a lot!
On May 29, 2014, at 12:41 PM, Archer, Charles J <[email protected]> wrote:
I hit this problem at some point as well, and proposed a patch…I kept the patch around in my git stash: Hopefully it helps you.
diff --git a/src/include/mpiimplthread.h b/src/include/mpiimplthread.h index f0141c6..c2e1cee 100644 --- a/src/include/mpiimplthread.h +++ b/src/include/mpiimplthread.h @@ -1039,5 +1039,18 @@ do { \ #define MPIU_THREAD_MPI_OBJ_FINALIZE(objptr_) do {} while (0) #endif
+#if defined(MPICH_IS_THREADED) && !defined(MPID_DEVICE_DEFINES_THREAD_CS) +static void +MPIU_Thread_CS_enter_lockname_impl_(enum MPIU_Nest_mutexes kind, + const char *lockname, + MPID_Thread_mutex_t *mutex); + + +static void +MPIU_Thread_CS_exit_lockname_impl_(enum MPIU_Nest_mutexes kind, + const char *lockname, + MPID_Thread_mutex_t *mutex); +#endif + #endif /* !defined(MPIIMPLTHREAD_H_INCLUDED) */
On May 29, 2014, at 11:29 AM, Greenberg, Hugh N <[email protected]> wrote:
I’m having a problem building mpich 3.1 with the enable-thread-cs=per-object build option. I get a lot of errors like these:
/src/include/mpiimplthreadpost.h:27: warning: conflicting types for 'MPIU_Thread_CS_enter_lockname_impl_' ./src/include/mpiimplthreadpost.h:27: error: static declaration of 'MPIU_Thread_CS_enter_lockname_impl_' follows non-static declaration ./src/include/mpiimpl.h:1280: note: previous implicit declaration of 'MPIU_Thread_CS_enter_lockname_impl_' was here
Is there a fix for this? Thanks. _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Archer, Charles J
