Re: [mpich-discuss] spurious lock ups on collective merge intercom
Thanks. it would not be easy for me to do immediately as i am using proprietary scala binding api for MPI. it would help me to know if there's a known problem like that in the past, or generally mergeIntercomm api is known to work on hundreds of processes. Sounds like there are no known issues with that. On Tue, Jan 10, 2017 at 11:53 PM, Oden, Lena <[email protected]> wrote:
Hello Dmittiy,
can you maybe create a simple example-program to reproduce this failure? It is also often easier also to look at a code example to identify a problem.
Thanks, Lena
On Jan 11, 2017, at 2:45 AM, Dmitriy Lyubimov <[email protected]> wrote:
Hello,
(mpich 3.2)
I have a scenario when i add a few extra processes do existing intercom.
it works as a simple loop -- (1) n processes accept on n-intercom (2) 1 process connects (3) intracom is merged into n+1 intercom, intracom and n-intercom are closed (4) repeat 1-3 as needed.
Occasionally, i observe that step 3 spuriously locks up (once i get in the range of 100+ processes). From what i can tell, all processes in step 3 are accounted for, and are waiting on the merge, but nothing happens. the collective barrier locks up.
I really have trouble resolving this issue, any ideas are appreciated!
Thank you very much. -Dmitriy
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Dmitriy Lyubimov
