Re: [mpich-discuss] Porting MPICH
I looked into this more thoroughly. The simple solution is to use "--with-thread-package=no --enable-threads=single" together. The latter will disable the use of all thread-related functions that lead to missing symbols due to the former. In short, a no-op implementation is not necessary, as I found out _after_ I had created one. Jeff On Mon, May 20, 2013 at 6:46 AM, jhonatan alves <[email protected]> wrote:
Hello, Today we will try the strategies proposed by you and see how it goes.
Thank you for helping
2013/5/19 Jeff Hammond <[email protected]>
Yeah, I would use the abort strategy to detect if MPICH is using thread-related functions in MPI_THREAD_SINGLE (ignoring MPICH_ASYNC_PROGRESS=1) and the noop implementation for practical purposes.
Jeff
On Sun, May 19, 2013 at 2:49 PM, Pavan Balaji <[email protected]> wrote:
Thanks. Yes, they can be mostly no-ops (except TLS checks which can be any static variable since there's only one thread by definition). Implementing them as "not-implemented" aborts might be OK too.
-- Pavan
On 05/19/2013 02:43 PM US Central Time, Jeff Hammond wrote:
Presumably those functions can be noops if no threads are going to be used. Am I wrong?
It might be worth implementing those functions as stubs that abort with UNIMPL error and see how far that goes. I'll try to get to this later today.
Jeff
On Sun, May 19, 2013 at 2:36 PM, Pavan Balaji <[email protected]> wrote:
On 05/19/2013 02:28 PM US Central Time, jhonatan alves wrote:
But i believe that the missing of POSIX threads can be the most trouble part. So we need to port to the thread implementation in EPOS.
Yup, I too believe that'll be the blocker. MPICH supports multiple threading packages, but currently requires at least one to function correctly:
https://trac.mpich.org/projects/mpich/ticket/231
It's been a while since I looked into this issue, but I could look into it if you are running into it for your platform.
-- Pavan
-- Pavan Balaji http://www.mcs.anl.gov/~balaji _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond ALCF docs: http://www.alcf.anl.gov/user-guides
participants (1)
Jeff Hammond
