Re: [mpich-discuss] MPICH-3.1.4 with PAMID: Win_lock
I recommend filing the bug regarding the supported MPI. I can't find any statement in the MPI standard indicating it shouldn't work. Jeff On Thu, Mar 30, 2017 at 8:34 AM, Sebastian Rinke <[email protected]> wrote:
Thanks a lot for your answer!
The same problem occurs in the supported MPI-2.2 on BGQ. Ok, I will try the OFI-based MPI-3.
Thanks, Sebastian
On 30 Mar 2017, at 17:12, Jeff Hammond <[email protected]> wrote:
I guess this is a bug but MPICH 3.1.x isn't the basis for the supported MPI on BGQ, so I doubt you will get much traction by reporting it. IBM made an effort to support MPI-3 with PAMID but it was as an open-source, best effort project, and I recall there were some issues with it, including deadlock in certain asynchronous operations.
You should try the supported MPI-2.2 implementation on BGQ or try the unsupported OFI-based implementation of MPI-3.
Disclaimer: The comments above are spoken in my capacity as the person who used to support MPI at ALCF, not my current job role.
Best,
Jeff
On Thu, Mar 30, 2017 at 3:21 AM, Sebastian Rinke <[email protected]
wrote:
Same window, i.e.:
Process 0:
Win_lock(MPI_LOCK_SHARED, target=A, window=win)
Win_lock(MPI_LOCK_SHARED, target=B, window=win)
Sebastian
On 30 Mar 2017, at 06:24, Jeff Hammond <[email protected]> wrote:
Same window or different windows?
Jeff
On Wed, Mar 29, 2017 at 5:59 PM Sebastian Rinke <[email protected]> wrote:
Dear all,
I have some issue with MPI_Win_lock in MPICH-3.1.4 on Blue Gene/Q.
Here is my example:
Process 0:
Win_lock(MPI_LOCK_SHARED, target=A) Win_lock(MPI_LOCK_SHARED, target=B)
No matter what I use for A and B (given A != B), a process cannot acquire more than one lock at a time.
To my understanding, it should be possible to acquire more than one lock.
Can you confirm this issue?
Thanks, Sebastian _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
