Re: [mpich-discuss] [MPICH compilation with NAG Fortran compiler]
We run nightly tests with the NAG compiler, and they build fine (see the 5th column from the right at http://www.mpich.org/static/cron/tests/). Can you try configuring with just the —prefix option to see if one of the options is the cause. Shared libraries are built by default. Rajeev
On Aug 6, 2015, at 6:25 AM, Maxim Abalenkov <[email protected]> wrote:
Dear Madam or Sir,
I’m facing a problem trying to compile MPICH with NAG Fortran compiler. The compilation breaks with an unrecognised option ‘—dynamic lib’ error. Please see the make log file called ‘m.txt’.
To configure MPICH version 3.2b4 I’m using the attached configure script. Please see the script for the MPICH configuration options. Configuration and compilation log files called ‘c.txt’ and ‘m.txt’ are also attached.
I would greatly appreciate your help in compiling MPICH with NAG Fortran. Thank you. Have a good day.
Product name and version: NAG Fortran Compiler Release 6.0 (Hibiya) Build 1021 OS: Mac OS X Yosemite 10.10.4 (64-bit)
— Best wishes, Maxim Abalenkov
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <mpich-configure-nag.sh><c.txt><m.txt>
participants (1)
Thakur, Rajeev
