Re: [mpich-discuss] mpich install error (libstdc++.so)
Hi Zhifeng, It looks like the Intel c++ compiler icpc is used for linking. Maybe you did not specify `CXX=g++` at configure time. Please try this (make sure all compilers are with the same version) ./configure <other config options> CC=gcc CXX=g++ FC=gfortran F77=gfortran If you still see the installation error, please send us the config.log at your build directory together with the error message. Min On 2018/10/18 8:28, Zhifeng Yang wrote: Hi I tried to install mpich using gcc. However, while make, I got the following error message. libtool: link: icpc -shared src/binding/cxx/.libs/initcxx.o -Wl,-rpath,/home/vy57456/zzbatmos_user/application/gfortran/source_code/mpich-3.2.1/lib/.libs -Wl,-rpath,/cm/shared/apps/gcc/4.8.4/lib/../lib -Wl,-rpath,/home/vy57456/zzbatmos_user/application/gfortran/mpich-3.2.1/lib -Wl,-rpath,/cm/shared/apps/gcc/4.8.4/lib/../lib lib/.libs/libmpi.so -lpthread -L/cm/shared/apps/intel/composer_xe/2015.5.223/ipp/../compiler/lib/intel64 -L/cm/shared/apps/intel/composer_xe/2015.5.223/ipp/lib/intel64 -L/cm/shared/apps/intel/composer_xe/2015.5.223/compiler/lib/intel64 -L/cm/shared/apps/intel/composer_xe/2015.5.223/mkl/lib/intel64 -L/cm/shared/apps/intel/composer_xe/2015.5.223/tbb/lib/intel64/gcc4.4 -L/cm/shared/apps/slurm/14.11.11/lib64/slurm -L/cm/shared/apps/slurm/14.11.11/lib64 -L/usr/cluster/contrib/hdf5/install-1.8.16/lib -L/cm/shared/apps/acml/current/ifort64/lib -L/cm/shared/apps/slurm/14.11.11/lib64/../lib64 -L/cm/shared/apps/slurm/14.11.11/lib64/../lib64/ -L/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/ -L/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../lib64 -L/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../../lib64/ -L/lib/../lib64 -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/ -L/cm/shared/apps/intel/composer_xe/2015.5.223/ipp/../compiler/lib/intel64/ -L/cm/shared/apps/intel/composer_xe/2015.5.223/ipp/lib/intel64/ -L/cm/shared/apps/intel/composer_xe/2015.5.223/compiler/lib/intel64/ -L/cm/shared/apps/intel/composer_xe/2015.5.223/mkl/lib/intel64/ -L/cm/shared/apps/intel/composer_xe/2015.5.223/tbb/lib/intel64/gcc4.4/ -L/cm/shared/apps/slurm/14.11.11/lib64/slurm/ -L/cm/shared/apps/slurm/14.11.11/lib64/ -L/usr/cluster/contrib/hdf5/install-1.8.16/lib/ -L/cm/shared/apps/acml/current/ifort64/lib/ -L/cm/shared/apps/gcc/4.8.4/lib/gcc/x86_64-unknown-linux-gnu/4.8.4/../../../ -L/lib64 -L/lib/ -L/usr/lib64 -L/usr/lib -limf -lirng -lm -lipgo -ldecimal -lcilkrts /cm/shared/apps/gcc/4.8.4/lib/../lib/libstdc++.so -lintlc -lsvml -lgcc -lgcc_s -lirc_s -ldl -lc -O2 -Wl,-soname -Wl,libmpicxx.so.12 -o lib/.libs/libmpicxx.so.12.1.1 /cm/shared/apps/gcc/4.8.4/lib/../lib/libstdc++.so: could not read symbols: File in wrong format make[2]: *** [lib/libmpicxx.la<http://libmpicxx.la>] Error 1 make[2]: Leaving directory `/umbc/xfs1/zzbatmos/users/vy57456/application/gfortran/source_code/mpich-3.2.1' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/umbc/xfs1/zzbatmos/users/vy57456/application/gfortran/source_code/mpich-3.2.1' make: *** [all] Error 2 Do you have any experience on this error? Thank you Zhifeng _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Si, Min
