Re: [mpich-discuss] illegal ioctl
I would suggest the first place you check is some data structures that expand as the number of MPI processes increases. — Huiwei On Apr 20, 2014, at 10:08 AM, Hans-Joachim Werner <[email protected]> wrote:
Thanks. Yes, most likely it runs out of some system resources. It happens independently of the other memory the job needs. We use Global Arrays with MPI, and the problem happens in ga_put (one-sided write to a global array). We can also run it with pure MPI, and the same problem occurs (it’s not SHMMAX). The application is the Molpro quantum chemistry program. Joachim Werner --- Prof. Dr. Hans-Joachim Werner Institut for Theoretical Chemistry University of Stuttgart Pfaffenwaldring 55 D-70569 Stuttgart Tel: +49 711 / 685 64400 Fax: +49 711 / 685 64442 email: [email protected]
Am 20.04.2014 um 16:52 schrieb Lu, Huiwei <[email protected]>:
It’s possible your system is running out of memory or other system resources that cause the MPI job to abort.
— Huiwei Lu Postdoc Appointee Mathematics and Computer Science Division, Argonne National Laboratory http://www.mcs.anl.gov/~huiweilu/
On Apr 20, 2014, at 9:49 AM, Balaji, Pavan <[email protected]> wrote:
This is not an MPICH problem. It means that your application is asking MPICH to kill it using “MPI_Abort”.
— Pavan
On Apr 20, 2014, at 7:48 AM, Hans-Joachim Werner <[email protected]> wrote:
On my system large jobs die with messages like this:
Last System Error Message from Task 3:: Inappropriate ioctl for device application called MPI_Abort(comm=0x84000004, 11) - process 3
Does anybody know how this can be avoided? Maybe a stack overflow?
Joachim Werner
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Lu, Huiwei
