Re: [mpich-discuss] how to run jobs using IPv6?
Hi Yanfei, Just friendly reminder If mpich contain the functions below which only supports IPv4, please replace them together gethostbyname/getservbyname => getaddrinfo gethostbyaddr => getnameinfo inet_ntoa => inet_ntop inet_aton => inet_pton socket/bind/accept/recv/recvfrom/send/sendto/ => API argument list changed I also comment under the ticket. Thanks Shuwei On Wed, 6 Dec 2017 at 12:21 Shuwei Zhao <[email protected]> wrote:
Hi yanfei Thanks for creating the ticket. Do you have any idea on how long this ticket will be handled and closed? I think for this ticket the code change should not be big. This feature is pretty urgent for my team. Thanks
On Wed, 6 Dec 2017 at 12:07 Guo, Yanfei <[email protected]> wrote:
I have created an ticket to track it. https://github.com/pmodels/mpich/issues/2889
Yanfei Guo Assistant Computer Scientist MCS Division, ANL
On 12/6/17, 11:52 AM, "Shuwei Zhao" <[email protected]> wrote:
Are you going to use getaddrinfo instead to deprecate gethostbyname?
Thanks
On Wed, 6 Dec 2017 at 11:50 Guo, Yanfei <[email protected]> wrote:
Hi Shuwei,
The communication over IPv6 network is supported as long as the lower-level network library supports it. However, MPICH uses gethostbyname to translate hostnames to addresses in order to initialize the link which is not working on pure IPv6.
On 12/6/17, 11:46 AM, "Shuwei Zhao" <[email protected]> wrote:
Hi Yanfei,
I ask this question months ago,but I was told IPv6 is supported in mpich 3.*. So it's not supported?
Thanks Shuwei
On Wed, 6 Dec 2017 at 11:24 Guo, Yanfei <[email protected]> wrote:
Hi Carlos,
MPICH currently uses gethostbyname which does not support IPv6, therefore it won’t work on a pure IPv6 network.
Best,
On 11/22/17, 2:23 PM, "Carlos" <[email protected]> wrote:
Is it possible to use mpich (3.3) with IPv6-only? We tried it here and got
Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(506)..............: MPID_Init(211).....................: channel initialization failed MPIDI_CH3_Init(89).................: MPID_nem_init(324).................: MPID_nem_tcp_init(178).............: MPID_nem_tcp_get_business_card(425): ckpt_restart(384)..................: gethostbyname failed, zuratkul (errno 4) *************
This shows that mpich doesn't run without IPv4, which is our case... Is there a way to make it work in this situation? _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Shuwei Zhao
