Re: [mpich-discuss] Specifying a timeout for MPI_Comm_Accept
Thanks, Matthieu. — Pavan On Sep 8, 2014, at 3:17 AM, Matthieu Dorier <[email protected]> wrote:
Hi Pavan,
With all the work on in situ analysis/visualization, non-blocking versions of MPI_Comm_accept/connect could become very useful in the future to easily couple simulations and visualization codes.
Here is an example: the VisIt software can use in situ, but right now the connection between VisIt and the simulation is done through a normal socket. The simulation will periodically call VisItDetectInput to check (in a non-blocking manner) if VisIt connected to the simulation.
I recently had to use VisIt with a master-worker type simulation, that is, the master has an MPI_Recv(MPI_ANY_SOURCE...) to wait for workers to finish pieces of work. When using VisIt, this simple MPI_Recv becomes a non-blocking receive an active loop alternating between an MPI_Testany and VisItDetectInput. If VisIt could leverage non-blocking accept/connect, this active loop could be replaced with an MPI_Waitany on a set of MPI_Requests, one of them being VisIt connecting (the result of an MPI_Comm_iaccept), the other being workers finishing some work.
I'm not a VisIt developer, though. This is just a thought.
Matthieu Dorier PhD student at ENS Rennes http://people.irisa.fr/Matthieu.Dorier ----- Mail original -----
De: "Pavan Balaji" <[email protected]> À: [email protected] Envoyé: Dimanche 7 Septembre 2014 00:53:58 Objet: Re: [mpich-discuss] Specifying a timeout for MPI_Comm_Accept
Hirak,
The function definitions for MPI_Comm_accept, etc., are a part of the MPI standard. We cannot change them in MPICH without changing them in the MPI standard first. Changes to the MPI standard go through the MPI Forum, and through a formal proposal and voting process before they get in.
FWIW, both a timeout model and a nonblocking connect/accept have been proposed in the past, but they were both voted down. The nonblocking connect/accept proposal was originally done by Josh Hursey (http://www.cs.uwlax.edu/~jjhursey/), but I’m planning to revive the ticket but more broadly asking for nonblocking variants for many other operations as well. It’s unclear if/when this will get in, but we can try.
The timeout proposal was put together by Jeff Squyres @ Cisco and Fab Tillier @ Microsoft (they are both on this list). I personally thought it was a very elegant proposal, but it was voted down because there was no use case for it at the time, particularly given that there was no standardized fault model in MPI. Once the Fault Tolerance working group gets its proposal in, there might be room to revisit this. But you’ll need to talk to the above mentioned guys to see if they are planning to revive it.
Hope that helps.
— Pavan
On Sep 6, 2014, at 12:35 PM, Roy, Hirak <[email protected]> wrote:
The thread at the end of my email, shows that there is no way we can specify a timeout in MPI_Comm_accept/connect. Since the thread is pretty old (2007), I would like to know if there is any development related to this or not?
If we still can not specify a timeout, is there any provision of non-blocking accept/connect ?
Thanks, Hirak
https://lists.mcs.anl.gov/mailman/htdig/mpich-discuss/2007-April/002159.html _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji ✉️ http://www.mcs.anl.gov/~balaji
participants (1)
Balaji, Pavan
