Re: [mpich-discuss] Semantics of MPI_Cancel
I might be reading this differently then everyone else, but it appears that you're asking which SEND would be matched, not which RECEIVE. Assuming you use the same communicator, tag, and recipient, messages in MPI are always guaranteed to be in order. So if you manage to cancel the Irecv in time, you'll receive the first send in the Recv and the second send will be waiting to be matched. There isn't a situation where you'd receive message number 2 before message number 1 or not receive message 1 at all. Wesley On Wednesday, August 7, 2013 at 7:16 PM, Matthieu Dorier wrote:
Ah great, thanks!
Matthieu
----- Mail original -----
De: "Rajeev Thakur" <[email protected] (mailto:[email protected])> À: [email protected] (mailto:[email protected]) Envoyé: Mercredi 7 Août 2013 16:34:18 Objet: Re: [mpich-discuss] Semantics of MPI_Cancel
MPI_Cancel will succeed only if the receive can be canceled, i.e., not part of the message has already been received into the receive buffer. So, if the cancel succeeds, the send will match the next receive. You have to check the error code returned by cancel.
On Aug 7, 2013, at 4:18 PM, Matthieu Dorier wrote:
So either there is no way to know which MPI_Send will be matched, since even with MPI_Irecv(req); MPI_Test(flag,req); if(!flag) {MPI_Cancel(req)} MPI_Recv() the MPI_Irecv could have completed between the MPI_Test and the MPI_Cancel...
Or does the content of the MPI_Irecv, which is supposed to have been put in the user-provided buffer, gets transferred into the buffer of the next MPI_Recv upon cancellation of the MPI_Irecv?
Matthieu
De: "Rajeev Thakur" <[email protected] (mailto:[email protected])> À: [email protected] (mailto:[email protected]) Envoyé: Mercredi 7 Août 2013 16:10:02 Objet: Re: [mpich-discuss] Semantics of MPI_Cancel
You canceled the recv, not the send. The send will still go through and match the first available receive that can be matched.
On Aug 7, 2013, at 3:25 PM, Matthieu Dorier wrote:
Suppose process 0 does the following MPI_Irecv(...req) MPI_Cancel(req) MPI_Recv
and process 1 does MPI_Send MPI_Send
Does process 0 receives the data from the first or the second MPI_Send? (I'd tend to say the second, but I'd like a confirmation).
Thanks!
Matthieu Dorier PhD student at ENS Cachan Brittany and IRISA http://people.irisa.fr/Matthieu.Dorier _______________________________________________ discuss mailing list [email protected] (mailto:[email protected]) To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Wesley Bland
