Re: [mpich-discuss] mpirun not running in batch mode.
Output of crontab -l # Edit this file to introduce tasks to be run by cron. MAILTO="[email protected]" # m h dom mon dow command #------------------------------------------------------------------ # Procesos relativos a la descarga de GFS #------------------------------------------------------------------ 00 6,18 * * * /home/meteo/RAMS/SCRIPTS/GFS_descarga_diaria.bash 30 8,20 * * * /home/meteo/RAMS/SCRIPTS/mail_logs.bash 15 6,18 * * * /home/meteo/RAMS/SCRIPTS/GFS_2_RAMS.bash 00 2 * * * /home/meteo/RAMS/SCRIPTS/limpia_logs.bash 00 2 * * * /home/meteo/RAMS/SCRIPTS/limpia_dp.bash 0,15,30,45 * * * * /home/meteo/RAMS/SCRIPTS/test-sistema-ventus.bash 0,15,30,45 * * * * /home/meteo/scripts/control-temperatura.bash 50 00,13 * * * /home/meteo/R/thalassa/RAMS-graficar-serie-temperatura-onades.bash # Prova d'execuci� de RAMS a les 7 i les 19 00 7,19 * * * /home/meteo/RAMS/SCRIPTS/RAMS_operatiu.bash El 11/06/2014 15:49, Lu, Huiwei escribi�:
Could you give us the output of the following command: "crontab -l" ?
� Huiwei
On Jun 11, 2014, at 8:02 AM, Francisco Pastor <[email protected]> wrote:
Hi
This file contains some model configuration parameter. It lies in the same directory where model is being executed. Don't think the problem comes from this point. The running command is rams60 (owned by meteo), a symbolic link to rams-6.0-opt (owned by root)
lrwxrwxrwx 1 meteo meteo 39 mar 12 11:57 rams60 -> /usr/local/rams60/build/60/rams-6.0-opt
-rwxr-xr-x 1 root root 5009008 jun 11 11:34 /usr/local/rams60/build/60/rams-6.0-opt
Thanks
El 11/06/2014 14:03, Lu, Huiwei escribi�:
Is the file RAMSIN.operatiu at the home directory? You may want to give cron script the complete path to that file.
� Huiwei
On Jun 11, 2014, at 3:55 AM, Francisco Pastor <[email protected]> wrote:
meteo@ventus:~/RAMS/RUN$ ps -ef | grep rams meteo 20324 18460 0 09:32 ? 00:00:00 python2 /usr/local/mpich2-1.0.5p4/bin/mpirun -envall -n 40 ./rams60 -f RAMSIN.operatiu
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- ----------- Dr. Francisco Pastor Meteorology department, Instituto Universitario CEAM-UMH http://www.ceam.es ----------- Mendeley profile: http://www.mendeley.com/profiles/francisco-pastor1/ Google Scholar: http://scholar.google.com/citations?user=V3mmCdkAAAAJ&hl=es Researcher ID: http://www.researcherid.com/rid/B-8331-2008 Cosis profile: http://www.cosis.net/profile/francisco.pastor ----------- mail: [email protected] skype: paco.pastor.guzman ----------- Parque Tecnologico, C/ Charles R. Darwin, 14 46980 PATERNA (Valencia), Spain Tlf. 96 131 82 27 - Fax. 96 131 81 90
--------------------------------------------------------------------- Este mensaje y los ficheros anexos son confidenciales. Los mismos contienen informaci�n reservada de la empresa que no puede ser difundida. Si usted ha recibido este correo por error, tenga la amabilidad de eliminarlo de su sistema y avisar al remitente mediante reenv�o a su direcci�n electr�nica; no deber� copiar el mensaje ni divulgar su contenido a ninguna persona.
Su direcci�n de correo electr�nico junto a sus datos personales forman parte de un fichero titularidad de la Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213, cuya finalidad es la de mantener el contacto con Ud. De acuerdo con la Ley Org�nica 15/1999, usted puede ejercitar sus derechos de acceso, rectificaci�n, cancelaci�n y, en su caso, oposici�n enviando una solicitud por escrito, acompa�ada de una fotocopia de su DNI dirigida a: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia).
This message and the attached files are confidential. They contain reserved information belonging to our centre and are not to be broadcast. If you have received this email by mistake, please delete it from your system and alert the sender by returning it to his/her email address. You must not copy or divulge the contents of the message to anyone.
Your email address and personal data are included in a file belonging to the Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213. The purpose of this file is to allow us to keep in contact with you. In accordance with Organic Law 15/1999, you are permitted to access, rectify, cancel or oppose the contents of this file by submitting a written request, accompanied by a photocopy of your DNI, to: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia).
-- ----------- Dr. Francisco Pastor Meteorology department, Instituto Universitario CEAM-UMH http://www.ceam.es ----------- Mendeley profile: http://www.mendeley.com/profiles/francisco-pastor1/ Google Scholar: http://scholar.google.com/citations?user=V3mmCdkAAAAJ&hl=es Researcher ID: http://www.researcherid.com/rid/B-8331-2008 Cosis profile: http://www.cosis.net/profile/francisco.pastor ----------- mail: [email protected] skype: paco.pastor.guzman ----------- Parque Tecnologico, C/ Charles R. Darwin, 14 46980 PATERNA (Valencia), Spain Tlf. 96 131 82 27 - Fax. 96 131 81 90 --------------------------------------------------------------------- Este mensaje y los ficheros anexos son confidenciales. Los mismos contienen informaci�n reservada de la empresa que no puede ser difundida. Si usted ha recibido este correo por error, tenga la amabilidad de eliminarlo de su sistema y avisar al remitente mediante reenv�o a su direcci�n electr�nica; no deber� copiar el mensaje ni divulgar su contenido a ninguna persona. Su direcci�n de correo electr�nico junto a sus datos personales forman parte de un fichero titularidad de la Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213, cuya finalidad es la de mantener el contacto con Ud. De acuerdo con la Ley Org�nica 15/1999, usted puede ejercitar sus derechos de acceso, rectificaci�n, cancelaci�n y, en su caso, oposici�n enviando una solicitud por escrito, acompa�ada de una fotocopia de su DNI dirigida a: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia). This message and the attached files are confidential. They contain reserved information belonging to our centre and are not to be broadcast. If you have received this email by mistake, please delete it from your system and alert the sender by returning it to his/her email address. You must not copy or divulge the contents of the message to anyone. Your email address and personal data are included in a file belonging to the Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213. The purpose of this file is to allow us to keep in contact with you. In accordance with Organic Law 15/1999, you are permitted to access, rectify, cancel or oppose the contents of this file by submitting a written request, accompanied by a photocopy of your DNI, to: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia).
participants (1)
Francisco Pastor
