Re: [mpich-discuss] Problem with Mpich3.0.4 build for WRF run across multiple nodes in a cluster.
On 06/21/2016 05:58 AM, Teck-Bin Arthur Lim wrote:
Hi ,
I met with a basic problem trying to get old mpich(3.0.4) version to do parallel run across different machines in a mini-cluster. The error messages
while invoking the mpiruns are :
*****************error messages********************
[limtba@fdns00_ws testenv-testlib]$ ./mpi-script
[limtba@fdns00_ws testenv-testlib]$ more log.aout
[mpiexec@fdns00_ws] HYDU_process_mfile_token (./utils/args/args.c:299): token cpu not supported at this time
[mpiexec@fdns00_ws] HYDU_parse_hostfile (./utils/args/args.c:347): unable to process token
what does your machine file look like? it sounds like you've got something in there that Hydra does not expect. ==rob
[mpiexec@fdns00_ws] mfile_fn (./ui/mpich/utils.c:341): error parsing hostfile
[mpiexec@fdns00_ws] match_arg (./utils/args/args.c:153): match handler returned error
[mpiexec@fdns00_ws] HYDU_parse_array (./utils/args/args.c:175): argument matching returned error
[mpiexec@fdns00_ws] parse_args (./ui/mpich/utils.c:1609): error parsing input array
[mpiexec@fdns00_ws] HYD_uii_mpx_get_parameters (./ui/mpich/utils.c:1660): unable to parse user arguments
[mpiexec@fdns00_ws] main (./ui/mpich/mpiexec.c:153): error parsing parameters
Command exited with non-zero status 255
This old version was downloaded from WRF site (http://www2.mmm.ucar.edu/wrf/OnLineTutorial/compilation_tutorial.php#STEP2) , and was built
with essentially, all the default configuration settings without any options arguments given in the configure/make/make-install process, as :
Ø./configure –prefix=$DIR/mpich
Ømake
Ømake install
There are no error messages during the built process, and the mpirun works fine for parallel runs, using multiple processors, on a single NODE only
but met with the above error messages when attempting parallel run across multiple machines.
I need some advice as to how get this old mpich 3.0.4 working across machines. The OS for these machines are Centos5.5, with gcc4.1.2 and
gcc4.4.7 installations. As WRF needs gcc4.4 and higher version, I have built the mpich3.04 using gcc4.4.7.
Would appreciate any help and advices…
Many Thanks.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Rob Latham
