Re: [mpich-discuss] MPI_Comm_spawn under torque
And a short update to the previous email, doing MPI_Comm_spawn even without the ssh launcher and using the native Torque TM interface does not work and returns the same error. So in general, I can do MPI_Comm_spawn under the Torque environment immaterial of the launcher that I use. Without the torque environment, it works fine. Best, Suraj On Feb 24, 2014, at 6:37 PM, Suraj Prabhakaran wrote:
Hello,
I am trying to do an MPI_Comm_spawn under Torque environment. But I want to use the ssh launcher instead of TM interface since there seems to be a problem with launching large processes through the TM interface. mpiexec across nodes in general works fine but when I spawn using MPI_Comm_spawn to do a remote spawn on another node, I get the following error.
mpiexec -launcher ssh -np 8 ./example
[pid 12026] starting up on host grsacc01! [pid 12027] starting up on host grsacc01! [pid 12028] starting up on host grsacc01! [pid 12021] starting up on host grsacc01! [pid 12023] starting up on host grsacc01! [pid 12025] starting up on host grsacc01! [pid 12022] starting up on host grsacc01! [pid 12024] starting up on host grsacc01! 0 completed MPI_Init 4 completed MPI_Init Parent [pid 12025] about to spawn! 5 completed MPI_Init 3 completed MPI_Init Parent [pid 12024] about to spawn! Parent [pid 12026] about to spawn! 2 completed MPI_Init Parent [pid 12023] about to spawn! 7 completed MPI_Init Parent [pid 12028] about to spawn! Parent [pid 12021] about to spawn! 6 completed MPI_Init Parent [pid 12027] about to spawn! 1 completed MPI_Init Parent [pid 12022] about to spawn! [pid 20535] starting up on host grsacc02! [pid 20536] starting up on host grsacc02! Assertion failed in file src/util/procmap/local_proc.c at line 112: my_node_id <= max_node_id internal ABORT - process 0 Assertion failed in file src/util/procmap/local_proc.c at line 112: my_node_id <= max_node_id internal ABORT - process 1
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 20535 RUNNING AT grsacc02 = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== [proxy:0:0@grsacc01] HYD_pmcd_pmip_control_cmd_cb (pm/pmiserv/pmip_cb.c:886): assert (!closed) failed [proxy:0:0@grsacc01] HYDT_dmxu_poll_wait_for_event (tools/demux/demux_poll.c:76): callback returned error status [proxy:0:0@grsacc01] main (pm/pmiserv/pmip.c:206): demux engine error waiting for event [mpiexec@grsacc01] HYDT_bscu_wait_for_completion (tools/bootstrap/utils/bscu_wait.c:76): one of the processes terminated badly; aborting [mpiexec@grsacc01] HYDT_bsci_wait_for_completion (tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion [mpiexec@grsacc01] HYD_pmci_wait_for_completion (pm/pmiserv/pmiserv_pmci.c:218): launcher returned error waiting for completion [mpiexec@grsacc01] main (ui/mpich/mpiexec.c:336): process manager error waiting for completion
Is there a way to get rid of this?
Best, Suraj
participants (1)
Suraj Prabhakaran
