Re: [mpich-discuss] MPICH 3.1.4 with Slurm 14.11.9
Hi Davide, I have tried your configuration on our machines and I could not reproduce the problem. Can you provide some more information about how you run into this problem? Yanfei Guo Postdoctoral Appointee MCS Division, ANL On 10/15/15, 10:40 AM, "Balaji, Pavan" <[email protected]> wrote:
Yanfei, Ken,
Notice that the user is having trouble because the SLURM path is not passed to the mpich test suite (not mpich itself). My guess is that we did something weird in passing the paths downstream since setting xFLAGS didn't help the user either.
-- Pavan
On 10/15/15, 10:37 AM, "Guo, Yanfei" <[email protected]> wrote:
Then, can you check if “/usr/scheduler/slurm/lib” is in ld’s search path. You can get that by running ldconfig -v 2>/dev/null | grep -v ^$'\t’
If not, you will need to set LIBRARY_PATH=“/usr/scheduler/slurm/lib” LD_LIBRARY_PATH=“/usr/scheduler/slurm/lib”
On 10/15/15, 10:34 AM, "Kenneth Raffenetti" <[email protected]> wrote:
I think this is the right solution, but should actually be "—with-slurm=/usr/scheduler/slurm". See the help text from configure:
-with-slurm=PATH specify path where slurm include directory and lib directory can be found
Ken
On 10/15/2015 10:25 AM, Guo, Yanfei wrote:
Can you try using “—with-slurm=/usr/scheduler/slurm/lib” when you run ./configure?
On 10/14/15, 3:21 PM, "Davide Vanzo" <[email protected]> wrote:
Pavan, maybe you missed in the crowd of my previous email. Anyway, yes, the library is there:
$ ls /usr/scheduler/slurm/lib libpmi2.a libpmi.la libslurmdb.la libslurm.so.28 libpmi2.la libpmi.so libslurmdb.so libslurm.so.28.0.0 libpmi2.so libpmi.so.0 libslurmdb.so.28 slurm libpmi2.so.0 libpmi.so.0.0.0 libslurmdb.so.28.0.0 libpmi2.so.0.0.0 libslurm.a libslurm.la libpmi.a libslurmdb.a libslurm.so
Davide
On Wed, 2015-10-14 at 20:17 +0000, Balaji, Pavan wrote:
Can you make sure you have SLURM's libpmi in the location you specified below (/usr/scheduler/slurm/lib)?
-- Pavan
From: Davide Vanzo Reply-To: "[email protected]" Date: Wednesday, October 14, 2015 at 2:29 PM To: "[email protected]" Subject: [mpich-discuss] MPICH 3.1.4 with Slurm 14.11.9
Hello all, I'm trying to compile MPICH 3.1.4 with GNU compilers 4.9.0 on a system with Slurm 14.11.9. I want to test the performance fall when using srun vs. mpiexec.hydra. I followed the guide and I added the slurm flags to configure as follows:
./configure --with-device=ch3:nemesis --prefix=$PREFIX --enable-fortran=yes --enable-cxx --enable-shared --with-pmi=slurm --with-pm=no --with-slurm=/usr/scheduler/slurm
The only compiler options I'm using are:
MPICHLIB_xFLAGS="-O3 -march=corei7"
MPICH builds correctly, but when I run make testing, I get the following error:
( cd test && make testing ) make[1]: Entering directory `/gpfs22/local/centos6/mpich/3.1.4/nehalem/gcc49/ether/source/test' (NOXMLCLOSE=YES && export NOXMLCLOSE && cd mpi && make testing) make[2]: Entering directory `/gpfs22/local/centos6/mpich/3.1.4/nehalem/gcc49/ether/source/test/mpi' ./runtests -srcdir=. -tests=testlist \ -mpiexec=/usr/local/mpich/3.1.4/nehalem/gcc49/ether/bin/mpiexec -xmlfile=summary.xml \ -tapfile=summary.tap -junitfile=summary.junit.xml Looking in ./testlist Processing directory attr Looking in ./attr/testlist Failed to build attrt; make[3]: Entering directory `/gpfs22/local/centos6/mpich/3.1.4/nehalem/gcc49/ether/source/test/mpi/attr' CC attrt.o CCLD attrt /usr/bin/ld: cannot find -lpmi collect2: ld returned 1 exit status make[3]: *** [attrt] Error 1 make[3]: Leaving directory `/gpfs22/local/centos6/mpich/3.1.4/nehalem/gcc49/ether/source/test/mpi/attr'
although /usr/scheduler/slurm/lib/libpmi.la exists. So I tried to explicitly use the lib and include path in the configure options: no luck. I also set "-L/usr/scheduler/slurm/lib" in the xFLAGS, but no effect. Any suggestion? Please let me know if I missed some information and thank you in advance for your help.
Best regards, Davide
-- Davide Vanzo, PhD Application Developer Advanced Computing Center for Research and Education (ACCRE) Vanderbilt University - Hill Center 201 www.accre.vanderbilt.edu <http://www.accre.vanderbilt.edu/>
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Guo, Yanfei
