Re: [mpich-discuss] Overlapping non-blocking collectives leads to deadlock
I realized something else relevant: I mentioned above that this deadlock occurs sometimes but not all of the time; I think I've narrowed down when it happens. Here's the above example with thread IDs annotated in: PROCESS 0 (root for ireduce and ibcast): // T0 is always the thread that calls MPI functions T0: MPI_Ireduce(..., &req) T0: MPI_Wait(&req); <-- blocking here ... T0: MPI_Ibcast(..., &req2); T0: MPI_Wait(&req2); PROCESS 1 (non-root for ireduce and ibcast): // T0 is the root for the reduce T0: MPI_Ireduce(..., &req) T0:MPI_Wait(&req); ... // T1 is the root for the bcast T1: MPI_Ibcast(..., &req2); T1: MPI_Wait(&req2); <-- blocking here Note that the non-root process has two different threads, T0 and T1, and T0 does the Ireduce and T1 does the bcast. I believe the T0 call to MPI_Ireduce is concurrent with the T1 call to MPI_Ibcast (both as non-roots). So, I believe the question is: is it legal in MPI to have two threads in a given MPI process call different non-blocking collectives (e.g., reduce and bcast) concurrently with MPI_THREAD_MULTIPLE enabled? Thank you On Mon, Nov 18, 2019 at 10:05 AM Mark Davis <[email protected]> wrote:
Hello, I'm experimenting with non-blocking collectives using MPICH in a multithreaded C++ program (with MPI_THREAD_MULTIPLE initialization).
I'm currently doing a non-blocking reduce followed by a non-blocking broadcast (I realize I can just use an allreduce but for my experiment, I need to serialize these operations). I was able to produce this bug with only two MPI processes. I see in gdb that the root process is stuck trying to execute the MPI_Ireduce in cases where the non-root process does the MPI_Ireduce and gets to the MPI_Ibcast quickly. That is, process 0 (root) isn't able to complete the MPI_Ireduce wait while process 1 is stuck in the MPI_Ibcast wait.
PROCESS 0 (root for ireduce and ibcast): MPI_Ireduce(..., &req) MPI_Wait(&req); <-- blocking here ... MPI_Ibcast(..., &req2); MPI_Wait(&req2);
PROCESS 1 (non-root for ireduce and ibcast): MPI_Ireduce(..., &req) MPI_Wait(&req); ... MPI_Ibcast(..., &req2); MPI_Wait(&req2); <-- blocking here
Much of the time, the program deadlocks as shown above; sometimes this works fine, though, perhaps due to subtle timing differences. I mentioned above that this is a multithreaded program. I'm able to produce the issue with two threads with two MPI procs. The other threads are not calling MPI functions -- they are helping with other computation. I've verified that I don't have any TSAN or ASAN errors in this program. However, when I only have one thread per process, I don't have this issue. I think there's a decent chance, though, that this has to do with timing differences as opposed to changing anything with the MPI calls. I have verified that only one thread per process is calling the MPI routines in the multithreaded case.
When I change the MPI_Ireduce to a blocking MPI_Reduce and I keep the MPI_Ibcast non-blocking, the program runs fine. Only when BOTH MPI_Ireduce and MPI_Ibcast happen serially do I see this deadlock (again, some of the time).
Unfortunately, this program is part of a very large system and it's not straightforward to give a fully working example. So, I'm just looking for any ideas anyone has for what sort of thing may be happening, any information that may be helpful about how two coincident non-blocking requests could interact with each other, etc.
Also, if anyone has tips on how to debug this sort of thing in gdb that would be helpful. For example, are there ways to introspect the MPI_Request object, etc.?
Thanks
participants (1)
Mark Davis
