Re: [mpich-discuss] Mpich over RDMA sample
Niyaz, FYI -https://urldefense.us/v3/__https://ofiwg.github.io/libfabric/v1.21.0/man/fi_... Hui ________________________________ From: Niyaz Murshed <[email protected]> Sent: Tuesday, June 18, 2024 11:00 AM To: Zhou, Hui <[email protected]>; [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample Hi Hui, When you say message semantic, do you mean endpoint type message ? Mpich is running over libfabric. When I run sample application on libfabric, it does have message endpoints over RMA. From: Zhou, Hui <zhouh@ anl. gov> Date: Tuesday, ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd Hi Hui, When you say message semantic, do you mean endpoint type message ? Mpich is running over libfabric. When I run sample application on libfabric, it does have message endpoints over RMA. From: Zhou, Hui <[email protected]> Date: Tuesday, June 18, 2024 at 9:44 AM To: Niyaz Murshed <[email protected]>, [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample The "verbs" provider alone does not provide the message semantics we needed for MPI. "ofi_rxm" is the utility provider that provides the message semantics. "verbs;ofi_rxm" is the provider combination you want. Hui ________________________________ From: Niyaz Murshed <[email protected]> Sent: Tuesday, June 18, 2024 9:14 AM To: Zhou, Hui <[email protected]>; [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample Hi Hui, I have set the env variable to FI_PROVIDER=verbs , after thich I get the below. libfabric provider: verbs;ofi_rxm - IB-0xfe80000000000000 It does not chose just “verbs” , it selects verbs;ofi_rxf I am wanting to select the below: provider: ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd Hi Hui, I have set the env variable to FI_PROVIDER=verbs , after thich I get the below. libfabric provider: verbs;ofi_rxm - IB-0xfe80000000000000 It does not chose just “verbs” , it selects verbs;ofi_rxf I am wanting to select the below: provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 I would really like to thank you for such fast responses. From: Zhou, Hui <[email protected]> Date: Tuesday, June 18, 2024 at 8:58 AM To: Niyaz Murshed <[email protected]>, [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample Niyaz, Set environment variable FI_PROVIDER=verbs to select the verbs provider. Hui ________________________________ From: Niyaz Murshed <[email protected]> Sent: Monday, June 17, 2024 8:57 PM To: Zhou, Hui <[email protected]>; [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample Hi Hui, I would still need some assistance in this. I am not able to make mpich chose verbs provider ☹ With the log : provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IN [16] 192. 168. 2. 200 Is my assumption to think the above log represent ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd Hi Hui, I would still need some assistance in this. I am not able to make mpich chose verbs provider ☹ With the log : provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 Is my assumption to think the above log represent that verbs provider knows about a path to 192.168.2.200 ? How does the application hello-world decide which provider to use? Running on server: 192.168.2.100 root@ampere-altra-2-1# FI_PROVIDER=verbs MPIR_CVAR_DEBUG_SUMMARY=1 mpirun -n 5 -hosts 192.168.2.200,192.168.2.100 /mpich/examples/a.out ==== Various sizes and limits ==== sizeof(MPIDI_per_vci_t): 192 Required minimum FI_VERSION: 0, current version: 10015 provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IB [48] provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IB [48] provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IB [48] provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IB [48] provider: verbs, score = 0, pref = 0, FI_FORMAT_UNSPEC [32] provider: verbs, score = 0, pref = 0, FI_FORMAT_UNSPEC [32] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxd, score = 5, pref = -2, FI_FORMAT_UNSPEC [32] provider: verbs;ofi_rxd, score = 5, pref = -2, FI_FORMAT_UNSPEC [32] Required minimum FI_VERSION: 10006, current version: 10015 ==== Capability set configuration ==== libfabric provider: verbs;ofi_rxm - IB-0xfe80000000000000 MPIDI_OFI_ENABLE_DATA: 0 MPIDI_OFI_ENABLE_AV_TABLE: 1 MPIDI_OFI_ENABLE_SCALABLE_ENDPOINTS: 0 MPIDI_OFI_ENABLE_SHARED_CONTEXTS: 0 MPIDI_OFI_ENABLE_MR_VIRT_ADDRESS: 1 MPIDI_OFI_ENABLE_MR_ALLOCATED: 1 MPIDI_OFI_ENABLE_MR_REGISTER_NULL: 1 MPIDI_OFI_ENABLE_MR_PROV_KEY: 1 MPIDI_OFI_ENABLE_TAGGED: 1 MPIDI_OFI_ENABLE_AM: 1 MPIDI_OFI_ENABLE_RMA: 1 MPIDI_OFI_ENABLE_ATOMICS: 0 MPIDI_OFI_FETCH_ATOMIC_IOVECS: 1 MPIDI_OFI_ENABLE_DATA_AUTO_PROGRESS: 0 MPIDI_OFI_ENABLE_CONTROL_AUTO_PROGRESS: 0 MPIDI_OFI_ENABLE_PT2PT_NOPACK: 1 MPIDI_OFI_ENABLE_TRIGGERED: 0 MPIDI_OFI_ENABLE_HMEM: 0 MPIDI_OFI_NUM_AM_BUFFERS: 8 MPIDI_OFI_NUM_OPTIMIZED_MEMORY_REGIONS: 0 MPIDI_OFI_CONTEXT_BITS: 16 MPIDI_OFI_SOURCE_BITS: 23 MPIDI_OFI_TAG_BITS: 20 MPIDI_OFI_VNI_USE_DOMAIN: 1 MAXIMUM SUPPORTED RANKS: 8388608 MAXIMUM TAG: 1048576 ==== Provider global thresholds ==== max_buffered_send: 192 max_buffered_write: 192 max_msg_size: 1073741824 max_order_raw: 1073741824 max_order_war: 0 max_order_waw: 1073741824 tx_iov_limit: 4 rx_iov_limit: 4 rma_iov_limit: 1 max_mr_key_size: 4 ==== Various sizes and limits ==== MPIDI_OFI_AM_MSG_HEADER_SIZE: 24 MPIDI_OFI_MAX_AM_HDR_SIZE: 255 sizeof(MPIDI_OFI_am_request_header_t): 416 sizeof(MPIDI_OFI_per_vci_t): 52480 MPIDI_OFI_AM_HDR_POOL_CELL_SIZE: 1024 MPIDI_OFI_DEFAULT_SHORT_SEND_SIZE: 16384 Assertion failed in file src/mpid/ch4/netmod/ofi/init_addrxchg.c at line 151: mapped_table[i] != FI_ADDR_NOTAVAIL Assertion failed in file src/mpid/ch4/netmod/ofi/init_addrxchg.c at line 151: mapped_table[i] != FI_ADDR_NOTAVAIL Assertion failed in file src/mpid/ch4/netmod/ofi/init_addrxchg.c at line 151: mapped_table[i] != FI_ADDR_NOTAVAIL Assertion failed in file src/mpid/ch4/netmod/ofi/init_addrxchg.c at line 151: mapped_table[i] != FI_ADDR_NOTAVAIL Assertion failed in file src/mpid/ch4/netmod/ofi/init_addrxchg.c at line 151: mapped_table[i] != FI_ADDR_NOTAVAIL If I do not use the FI_PROVIDER=verbs, it will work over sockets. root@ampere-altra-2-1: # MPIR_CVAR_DEBUG_SUMMARY=1 mpirun -n 5 -hosts 192.168.2.200,192.168.2.100 /mpich/examples/a.out ==== Various sizes and limits ==== sizeof(MPIDI_per_vci_t): 192 Required minimum FI_VERSION: 0, current version: 10015 provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IB [48] provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IB [48] provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IB [48] provider: verbs, score = 0, pref = 0, FI_SOCKADDR_IB [48] provider: verbs, score = 0, pref = 0, FI_FORMAT_UNSPEC [32] provider: verbs, score = 0, pref = 0, FI_FORMAT_UNSPEC [32] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN [16] 10.118.91.159 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 10.118.91.159 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 10.118.91.159 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 10.118.91.159 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: verbs;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IB [48] provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 10.118.91.159 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: verbs;ofi_rxd, score = 5, pref = -2, FI_FORMAT_UNSPEC [32] provider: verbs;ofi_rxd, score = 5, pref = -2, FI_FORMAT_UNSPEC [32] provider: udp;ofi_rxd, score = 5, pref = -2, FI_SOCKADDR_IN [16] 192.168.2.200 provider: udp;ofi_rxd, score = 5, pref = -2, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: udp;ofi_rxd, score = 5, pref = -2, FI_SOCKADDR_IN [16] 10.118.91.159 provider: udp;ofi_rxd, score = 5, pref = -2, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: udp;ofi_rxd, score = 5, pref = -2, FI_SOCKADDR_IN [16] 127.0.0.1 provider: udp;ofi_rxd, score = 5, pref = -2, FI_SOCKADDR_IN6 [28] ::1 provider: shm, score = 4, pref = -2, FI_ADDR_STR [14] - fi_shm://1177 provider: shm, score = 4, pref = -2, FI_ADDR_STR [14] - fi_shm://1177 provider: udp, score = 0, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: udp, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: udp, score = 0, pref = 0, FI_SOCKADDR_IN [16] 10.118.91.159 provider: udp, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: udp, score = 0, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: udp, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: tcp, score = 0, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: tcp, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: tcp, score = 0, pref = 0, FI_SOCKADDR_IN [16] 10.118.91.159 provider: tcp, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: tcp, score = 0, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN [16] 10.118.91.159 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: sockets, score = 3, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: sockets, score = 3, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: sockets, score = 3, pref = 0, FI_SOCKADDR_IN [16] 10.118.91.159 provider: sockets, score = 3, pref = 0, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: sockets, score = 3, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: sockets, score = 3, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN [16] 10.118.91.159 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN [16] 192.168.2.200 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN6 [28] fe80::526b:4bff:fefc:1342 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN [16] 10.118.91.159 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN6 [28] fe80::be97:e1ff:fe9d:7caa provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: sm2, score = 3, pref = 0, FI_ADDR_STR [13] - fi_sm2://1177 provider: sm2, score = 3, pref = 0, FI_ADDR_STR [13] - fi_sm2://1177 Required minimum FI_VERSION: 10005, current version: 10015 ==== Capability set configuration ==== libfabric provider: sockets - 192.168.2.0/24 MPIDI_OFI_ENABLE_DATA: 1 MPIDI_OFI_ENABLE_AV_TABLE: 1 MPIDI_OFI_ENABLE_SCALABLE_ENDPOINTS: 1 MPIDI_OFI_ENABLE_SHARED_CONTEXTS: 0 MPIDI_OFI_ENABLE_MR_VIRT_ADDRESS: 0 MPIDI_OFI_ENABLE_MR_ALLOCATED: 0 MPIDI_OFI_ENABLE_MR_REGISTER_NULL: 1 MPIDI_OFI_ENABLE_MR_PROV_KEY: 0 MPIDI_OFI_ENABLE_TAGGED: 1 MPIDI_OFI_ENABLE_AM: 1 MPIDI_OFI_ENABLE_RMA: 1 MPIDI_OFI_ENABLE_ATOMICS: 1 MPIDI_OFI_FETCH_ATOMIC_IOVECS: 1 MPIDI_OFI_ENABLE_DATA_AUTO_PROGRESS: 0 MPIDI_OFI_ENABLE_CONTROL_AUTO_PROGRESS: 0 MPIDI_OFI_ENABLE_PT2PT_NOPACK: 1 MPIDI_OFI_ENABLE_TRIGGERED: 0 MPIDI_OFI_ENABLE_HMEM: 0 MPIDI_OFI_NUM_AM_BUFFERS: 8 MPIDI_OFI_NUM_OPTIMIZED_MEMORY_REGIONS: 0 MPIDI_OFI_CONTEXT_BITS: 20 MPIDI_OFI_SOURCE_BITS: 0 MPIDI_OFI_TAG_BITS: 31 MPIDI_OFI_VNI_USE_DOMAIN: 1 MAXIMUM SUPPORTED RANKS: 4294967296 MAXIMUM TAG: 2147483648 ==== Provider global thresholds ==== max_buffered_send: 255 max_buffered_write: 255 max_msg_size: 9223372036854775807 max_order_raw: -1 max_order_war: -1 max_order_waw: -1 tx_iov_limit: 8 rx_iov_limit: 8 rma_iov_limit: 8 max_mr_key_size: 8 ==== Various sizes and limits ==== MPIDI_OFI_AM_MSG_HEADER_SIZE: 24 MPIDI_OFI_MAX_AM_HDR_SIZE: 255 sizeof(MPIDI_OFI_am_request_header_t): 416 sizeof(MPIDI_OFI_per_vci_t): 52480 MPIDI_OFI_AM_HDR_POOL_CELL_SIZE: 1024 MPIDI_OFI_DEFAULT_SHORT_SEND_SIZE: 16384 ==== OFI dynamic settings ==== num_vcis: 1 num_nics: 1 ====================================== error checking : enabled QMPI : disabled debugger support : disabled thread level : MPI_THREAD_SINGLE thread CS : per-vci threadcomm : enabled ==== data structure summary ==== sizeof(MPIR_Comm): 1808 sizeof(MPIR_Request): 512 sizeof(MPIR_Datatype): 280 ================================ Hello world from process 0 of 5 Hello world from process 2 of 5 Hello world from process 1 of 5 Hello world from process 4 of 5 Hello world from process 3 of 5 From: Zhou, Hui <[email protected]> Date: Wednesday, June 12, 2024 at 7:22 PM To: Niyaz Murshed <[email protected]>, [email protected] <[email protected]> Subject: Re: Mpich over RDMA sample It’s possible that the native path for RMA on verbs are turned off due to verbs does not meet MPI’s full atomic ordering semantics. We’ll check and follow up. -- Hui Zhou From: Niyaz Murshed <[email protected]> Date: Wednesday, June 12, 2024 at 3:59 PM To: Zhou, Hui <[email protected]>, [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample I think image is not gone : https: //ibb. co/RDGnJfy From: Niyaz Murshed <Niyaz. Murshed@ arm. com> Date: Wednesday, June 12, 2024 at 3: 56 PM To: Zhou, Hui <zhouh@ anl. gov>, discuss@ mpich. org <discuss@ mpich. org> Cc: nd <nd@ arm. com> ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd I think image is not gone : https://urldefense.us/v3/__https://ibb.co/RDGnJfy__;!!G_uCfscf7eWS!Z-ju_mFvc... <https://urldefense.us/v3/__https:/ibb.co/RDGnJfy__;!!G_uCfscf7eWS!YH6L3OHfPHd8aABguKjC1E2ZLYeI_yAUdgQlvdFFY5HHl8tDGe186dWz5LcggM9kcgEiwET4m3XOQ-HTMpo$> From: Niyaz Murshed <[email protected]> Date: Wednesday, June 12, 2024 at 3:56 PM To: Zhou, Hui <[email protected]>, [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample Thank you Hui for the reply. I was expecting to see RoCE messages in the packet capture. When I use verbs on libfabric sample tests, I see the RoCE messages as below : [cid:[email protected]] From: Zhou, Hui <[email protected]> Date: Wednesday, June 12, 2024 at 3:41 PM To: Niyaz Murshed <[email protected]>, [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample Niyaz, ofi_rxm:verbs is the correct provider. The ofi_rxm provides the verbs provider additional messaging semantics that are needed to be used in MPI. -- Hui Zhou From: Niyaz Murshed <[email protected]> Date: Wednesday, June 12, 2024 at 2:54 PM To: Zhou, Hui <[email protected]>, [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample Thank you for the reply. I did that; however, it selects ofi_rxm: verbs libfabric: 412098: 1718221892: : ofi_rxm: av: ofi_av_insert_addr(): 313<info> fi_addr: 1 libfabric: 412099: 1718221892: : ofi_rxm: av: ofi_av_insert_addr(): 313<info> fi_addr: ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd Thank you for the reply. I did that; however, it selects ofi_rxm:verbs libfabric:412098:1718221892::ofi_rxm:av:ofi_av_insert_addr():313<info> fi_addr: 1 libfabric:412099:1718221892::ofi_rxm:av:ofi_av_insert_addr():313<info> fi_addr: 1 options: backend: cpu iters: 16 warmup_iters: 16 cache: 1 min_elem_count: 1 max_elem_count: 1 elem_counts: [1] validate: last window_size: 64 #------------------------------------------------------------ # Benchmarking: Bandwidth # #processes: 2 #------------------------------------------------------------ #bytes #repetitions Mbytes/sec 4 16 0.02 # All done libfabric:412098:1718221892::ofi_rxm:ep_ctrl:rxm_stop_listen():864<info> stopping CM thread libfabric:412099:1718221892::ofi_rxm:ep_ctrl:rxm_stop_listen():864<info> stopping CM thread As per https://urldefense.us/v3/__https://www.intel.com/content/www/us/en/docs/mpi-... <https://urldefense.us/v3/__https:/www.intel.com/content/www/us/en/docs/mpi-library/developer-guide-linux/2021-6/ofi-providers-support.html__;!!G_uCfscf7eWS!YajPk9G-sPCEDt44nrZQrYG8r7V_s953AsKjQ4w_vW5OzcjJXfdGHOINW-PEYIw-IcISZSCw1xIsIoJ-dbE$> , we need to add FI_PROVIDER=^ofi_rxm , but if do that, it moves back to sockets provider. Is here a way to combine ^ofi_rxm and verbs From: Zhou, Hui <[email protected]> Date: Wednesday, June 12, 2024 at 2:41 PM To: Niyaz Murshed <[email protected]>, [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample Niyaz, All you need to do is to set an environment variable `FI_PROVIDER=verbs`. -- Hui Zhou From: Niyaz Murshed <[email protected]> Date: Wednesday, June 12, 2024 at 1:23 PM To: Zhou, Hui <[email protected]>, [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample When testing with Libfabric, verbs provider is selected. I did have to use “-e msg -d mlx5_1” so that it selects verbs. I was checking if there is anything like that for mpich sample tests. Else might need to do some hack in the code to force ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd When testing with Libfabric, verbs provider is selected. I did have to use “-e msg -d mlx5_1” so that it selects verbs. I was checking if there is anything like that for mpich sample tests. Else might need to do some hack in the code to force the selection of verbs. From: Zhou, Hui <[email protected]> Date: Wednesday, June 12, 2024 at 1:15 PM To: [email protected] <[email protected]> Cc: Niyaz Murshed <[email protected]>, nd <[email protected]> Subject: Re: Mpich over RDMA sample Libfabric support multiple providers. Sounds like it was selecting the sockets or tcp provider rather than a provider that support RoCE. I am not exactly sure whether the verbs provider will do that. If you can confirm the provider using libfabric tests, then you can try forcing MPICH to use that provider by setting the FI_PROVIDER environment variable. -- Hui Zhou From: Niyaz Murshed via discuss <[email protected]> Date: Wednesday, June 12, 2024 at 9:03 AM To: [email protected] <[email protected]> Cc: Niyaz Murshed <[email protected]>, nd <[email protected]> Subject: [mpich-discuss] Mpich over RDMA sample Hello, I am trying to learn about MPICH and its performance over RDMA. I am using libfabric and installed mpich using the below configure. ./configure --prefix=/opt/mpich/ --with-ofi=/opt/libfabric/ When I run any applications between 2 directly ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd Hello, I am trying to learn about MPICH and its performance over RDMA. I am using libfabric and installed mpich using the below configure. ./configure --prefix=/opt/mpich/ --with-ofi=/opt/libfabric/ When I run any applications between 2 directly connected servers having Mellanox NICs, I see that communication is happening over tcp and not over RoCE. Is there any way to test commination over RoCE ? For eg. I was able to test it for libfabric using the below sample that comes along with libfabric to test RMA. Is there something similar for MPICH ? or use the current sample to use RoCE by some parameter? Server : fi_rma_bw -s 192.168.1.100 -e msg -d mlx5_1 -S 1024 -I 1 Client : fi_rma_bw -s 192.168.1.200 -e msg -d mlx5_3 192.168.1.100 -S 1024 -I 1 Regards, Niyaz
participants (1)
Zhou, Hui
