Re: [mpich-discuss] How to terminate MPI_Comm_accept
Can you send us a simple program that reproduces the issue? — Pavan On Oct 8, 2014, at 2:54 PM, Roy, Hirak <[email protected]> wrote:
Hi Pavan,
I even tried duping the communicator (MPI_COMM_SELF à DUP1, DUP2) before I do any kind of MPI calls. Still it does not work.
Thanks, Hirak
You cannot do a Comm_dup when another thread is doing a collective call on the same communicator (e.g., Comm_accept).
On Oct 8, 2014, at 2:36 PM, Roy, Hirak <Hirak_Roy at mentor.com> wrote:
Hi Pavan,
I tried doing dup on both sides as well as on the client side only. Both cases, it did not work.
Thanks, Hirak
Here is the server-side
MPI_Comm dupCom ; MPI_Comm_dup (MPI_COMM_SELF, &dupCom); do { MPI_Comm newComm ; MPI_Comm_accept (m_serverPort.c_str(), MPI_INFO_NULL, 0, dupCom, &newComm); int buf = 0 ; MPI_Status status ; Log ("Waiting on receive"); MPI_Recv(&buf, 1, MPI_INT, MPI_ANY_SOURCE, MPI_ANY_TAG, newComm, &status); Log ("Receive complete"); if (status.MPI_TAG == MPI_MSG_TAG_NEW_CONN) { m_clientComs[m_clientCount] = newComm ; m_clientCount++; } else if (status.MPI_TAG == MPI_MSG_TAG_SHUTDOWN) { Log ("Shutdown"); MPI_Comm_disconnect (&newComm); Log ("Disconnect"); break; } else { Log ("Unmatched Receive"); } } while(1) ;
Are you doing MPI_Comm_dup while the other thread is doing MPI_Comm_accept?
— Pavan
From: Roy, Hirak Sent: Thursday, October 09, 2014 12:55 AM To: discuss at mpich.org Subject: Re: Re: Re: How to terminate MPI_Comm_accept
Hi Pavan,
Does not work. Crash in nemesis. Sock hangs in MPI_Recv/MPI_Send
Thanks, Hirak
MPI_Comm newComm ; MPI_Comm dupCom ; MPI_Comm_dup (MPI_COMM_SELF, &dupCom); MPI_Comm_connect (m_serverPort.c_str(), MPI_INFO_NULL, 0, dupCom, &newComm); Log ("Connect to Self"); int val = 0 ; MPI_Request req ; MPI_Send(&val, 1, MPI_INT, 0, MPI_MSG_TAG_SHUTDOWN, newComm); Log ("Successful"); MPI_Comm_disconnect(&newComm);
On Oct 8, 2014, at 11:41 AM, Roy, Hirak <Hirak_Roy at mentor.com> wrote:
Is there any way to come out of the blocking accept?
You can dup MPI_COMM_SELF and do the connect using that other communicator.
— Pavan
_________________________
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji ✉️ http://www.mcs.anl.gov/~balaji _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
