Re: [mpich-discuss] ROMIO filesystem check during MPI_File_open
On 03/24/2014 02:49 PM, Jeff Squyres (jsquyres) wrote:
On Mar 14, 2014, at 11:23 AM, Rob Latham <[email protected]> wrote:
I thought we handled this? we certianly seem to have made an effort:
https://trac.mpich.org/projects/mpich/browser/src/mpi/romio/adio/common/ad_f...
Sorry for the delay in getting back to this...
It looks like ADIO_FileSysType_fncall() is *not* collective -- it just does some magic to figure out what the local filesystem type is.
that's correct. we expect _fncall to be called from one process in the "no nfs" case, and from every process in the "nfs enabled" case.
Then back up in ADIO_ResolveFileType(),
that's called from two locations: MPI_File_open and MPI_File_delete. the only two functions that take a path and not an MPI_File handle. Open is collective, delete is not, but delete calls ResolveFileType with COMM_SELF (and you're not worried about the delete path anyway)
since have_nfs_enabled==1 and ADIO_FileSysType_fncall() returned MPI_SUCCESS,
Every process will call ADIO_FileSysType_fncall() in the case where have_nfs_enabled==1 . Your interpretation of the code is so different from mine that I'm just going to have to past what I'm looking at and you can tell me where I'm wrong. These lines come from MPICH's ad_fstype.c. The content is the same in openmpi-1.6.4, just shifted by 25 or so lines: 637 ADIO_FileSysType_fncall(filename, &file_system, &myerrcode); 638 if (myerrcode != MPI_SUCCESS) { 639 *error_code = myerrcode; 640 [ giant comment omitted...] 651 652 MPI_Allreduce(error_code, &max_code, 1, MPI_INT, MPI_MAX, comm); 653 if (max_code != MPI_SUCCESS) { 654 *error_code = max_code; 655 return; 656 } 657 /* ensure everyone came up with the same file system type */ 658 MPI_Allreduce(&file_system, &min_code, 1, MPI_INT, 659 MPI_MIN, comm); 660 if (min_code == ADIO_NFS) file_system = ADIO_NFS; 661 }
MPI_Allreduce() is *not* called, and each process just proceeds with their local value for file_system.
as you can see, there is an ALLREDUCE on the error code. Did anyone run into problems when we stat-ed the file system? If so, bail out early. If not, then let's figure out the common file system with a second ALLREDUCE.
That's where things go downhill: one process will get UFS, the rest will get NFS.
Yeah, that would be a problem, and I'll gladly fix this code, but I can't see where we are failing. Am I looking in the right place? ==rob -- Rob Latham Mathematics and Computer Science Division Argonne National Lab, IL USA
participants (1)
Rob Latham
