Re: [mpich-discuss] ssh-less MPI using docker exec?
Christian, Supporting a new launcher is fairly trivial in Hydra (mpich's process manager). You'd need to create something similar to 'ssh' in here: http://git.mpich.org/mpich.git/tree/HEAD:/src/pm/hydra/tools/bootstrap/exter... In fact, based on a google search, I found this: https://docs.docker.com/engine/reference/commandline/exec/ It looks like you can simply replace "ssh" with "docker exec" to get the required behavior? If that is correct, can you try launching mpich this way: % HYDRA_LAUNCHER_EXTRA_ARGS=exec mpiexec -hosts host1,host2 -launcher-exec 'docker' ./foo -- Pavan
On Apr 3, 2016, at 4:56 AM, Christian Kniep <[email protected]> wrote:
Hey Pavan,
I sparked a discussion on the github repo of Open MPI: https://github.com/open-mpi/ompi/issues/1511 But I assume that a docker-native execution model would also do for MPICH.
Cheers Christian
On 3 April 2016 at 05:18:36, Balaji, Pavan ([email protected]) wrote:
Did you mean to send this to the Open MPI mailing list?
-- Pavan
On Mar 31, 2016, at 12:56 PM, Christian Kniep <[email protected]> wrote:
Hey there,
I tinkered around with a ssh-less openmpi and I was wondering if it could be implemented in a nicer way. http://qnib.org/2016/03/31/dssh/
I just used -mca plm_rsh_agent /opt/qnib/src/dssh with a rather simple script to use docker exec:
#!/bin/bash
REMOTE_HOST=$1 shift set -x docker -H unix:///var/run/docker.sock exec -i -u ${USER} ${REMOTE_HOST} $@
Cheers Christian
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
