mpich 4.3.0 compilation problem when using --with-hcoll=/opt/mellanox/hcoll
Hello mpich community, When I try to compile mpich 4.3.0 configured with --with-hcoll=/opt/mellanox/hcoll option, I get a compilation error because the hcoll_do_progress() function is defined with two arguments in hcoll_init.c but it is called only with one in hcoll_rte.c ! Here is the error message I get: src/mpid/common/hcoll/hcoll_rte.c: In function 'progress': src/mpid/common/hcoll/hcoll_rte.c:58:33: warning: passing argument 1 of 'hcoll_do_progress' makes integer from pointer without a cast [-Wint-conversion] 58 | ret = hcoll_do_progress(&made_progress); | ^~~~~~~~~~~~~~ | | | int * In file included from ./src/mpid/ch4/netmod/include/../ucx/ucx_coll.h:11, from ./src/mpid/ch4/netmod/include/../ucx/netmod_inline.h:15, from ./src/mpid/ch4/netmod/include/netmod_impl.h:1589, from ./src/mpid/ch4/include/mpidch4.h:448, from ./src/mpid/ch4/include/mpidpost.h:10, from ./src/include/mpiimpl.h:232, from src/mpid/common/hcoll/hcoll_rte.c:6: ./src/mpid/ch4/netmod/include/../ucx/../../../common/hcoll/hcoll.h:42:27: note: expected 'int' but argument is of type 'int *' 42 | int hcoll_do_progress(int vci, int *made_progress); | ~~~~^~~ src/mpid/common/hcoll/hcoll_rte.c:58:15: error: too few arguments to function 'hcoll_do_progress' 58 | ret = hcoll_do_progress(&made_progress); | ^~~~~~~~~~~~~~~~~ In file included from ./src/mpid/ch4/netmod/include/../ucx/ucx_coll.h:11, from ./src/mpid/ch4/netmod/include/../ucx/netmod_inline.h:15, from ./src/mpid/ch4/netmod/include/netmod_impl.h:1589, from ./src/mpid/ch4/include/mpidch4.h:448, from ./src/mpid/ch4/include/mpidpost.h:10, from ./src/include/mpiimpl.h:232, from src/mpid/common/hcoll/hcoll_rte.c:6: ./src/mpid/ch4/netmod/include/../ucx/../../../common/hcoll/hcoll.h:42:5: note: declared here 42 | int hcoll_do_progress(int vci, int *made_progress); | ^~~~~~~~~~~~~~~~~ I use to compile mpich versions 3.4,x, 4.1.x, and 4.2.x configured with this option (--with-hcoll=) in the past without any problems. It looks like some recent changes in the related files introduced a problem that slip into 4.3.0 and makes compilation impossible. Could it be fixed ? Or could the --with-hcoll option be removed if it is no longer relevant (I guess that if we use ch4:ucx, ucx may itself use hcoll internally to optimize collective operations when running on hierarchical environment) ? Here are some details: arch: x86_64 OS: RHEL 9.5 (up to date except kernel) MOFED: 24.10-2.1.8.0-LTS hcoll: 4.8.3230-1.2410068 ucx: 1.18.0-1.2410068 The complete configuration line: ./configure --with-device=ch4:ucx --with-hcoll=/opt/mellanox/hcoll --prefix=/work/software/x86_64/mpich/mpich-ch4_ucx-4.3.0 --with-xpmem --enable-g=none --enable-fast=all --enable-romio --with-file-system=ufs+nfs+lustre --enable-shared --enable-sharedlibs=gcc Thanks, Martin Audet
participants (1)
Audet, Martin
