success and failure report for mpich-3.0.2
Hi today I tried to install mpich-3.0.2. I could compile and install the package for the following architectures. openSuSE Linux 12.1, x86_64, Sun C 5.12, 64-bit Solaris 10, x86_64, Sun C 5.12, 64-bit Solaris 10, sparc, Sun C 5.12, 32-bit Solaris 10, sparc, Sun C 5.12, 64-bit As described in the RELEASE_NOTES a communication between little-endian and big-endian machines is not possible (broken pipe). Unfortunately you don't even allow different operating systems (it seems that you don't evaluate PATH to find a program). sunpc1 fd1026 103 mpiexec -np 2 -host sunpc0,sunpc1 init_finalize Hello! Hello! sunpc1 fd1026 104 mpiexec -np 2 -host sunpc0,linpc1 init_finalize [proxy:0:1@linpc1] HYDU_create_process (../../../../mpich-3.0.2/src/pm/hydra/utils/launch/launch.c:74): execvp error on file init_finalize (No such file or directory) ======================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 255 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ======================================================================== [proxy:0:0@sunpc0] HYD_pmcd_pmip_control_cmd_cb (../../../../mpich-3.0.2/src/pm/hydra/pm/pmiserv/pmip_cb.c:886): assert (!closed) failed [proxy:0:0@sunpc0] HYDT_dmxu_poll_wait_for_event (../../../../mpich-3.0.2/src/pm/hydra/tools/demux/demux_poll.c:77): callback returned error status [proxy:0:0@sunpc0] main (../../../../mpich-3.0.2/src/pm/hydra/pm/pmiserv/pmip.c:206): demux engine error waiting for event The programs are available on both machines. sunpc1 fd1026 105 which init_finalize /home/fd1026/SunOS/x86_64/bin/init_finalize sunpc1 fd1026 106 ssh linpc1 which init_finalize /home/fd1026/Linux/x86_64/bin/init_finalize sunpc1 fd1026 107 I wasn't able to build the package on the following architectures. openSuSE Linux 12.1, x86_64, Sun C 5.12, 32-bit openSuSE Linux 12.1, x86_64, GNU C 4.7.1, 32-bit ------------------------------------------------ tyr mpich-3.0.2-Linux.x86_64.32_cc 158 tail log.make.Linux.x86_64.32_cc CC mplstr.lo CC mpltrmem.lo CC mplenv.lo CCLD libmpl.la /usr/lib/libxml2.so: could not read symbols: File in wrong format make[2]: *** [libmpl.la] Error 2 make[2]: Leaving directory `.../src/mpl' make[1]: *** [all-recursive] Error 1 openSuSE Linux 12.1, x86_64, GNU C 4.7.1, 64-bit ------------------------------------------------ tyr mpich-3.0.2-Linux.x86_64.64_gcc 171 tail log.make.Linux.x86_64.64_gcc CC mpltrmem.lo CC mplenv.lo CCLD libmpl.la /usr/local/bin/ld: libmpl.so.1: No such file: No such file or directory collect2: error: ld returned 1 exit status make[2]: *** [libmpl.la] Error 1 make[2]: Leaving directory `.../src/mpl' Solaris 10, x86_64, Sun C 5.12, 32-bit -------------------------------------- hangs Solaris 10, x86_64, GNU C 4.7.1, 32-bit --------------------------------------- tyr mpich-3.0.2-SunOS.x86_64.32_gcc 193 tail -12 log.make.SunOS.x86_64.32_gcc CC src/mpi/coll/barrier_group.lo CC src/mpi/coll/helper_fns.lo Assembler: helper_fns.c "/var/tmp//ccIdXgrh.s", line 912 : Syntax error Near line: "mov $PREFETCHBLOCK/16, %eax" "/var/tmp//ccIdXgrh.s", line 920 : Syntax error Near line: "mov $PREFETCHBLOCK/8, %eax" make[2]: *** [src/mpi/coll/helper_fns.lo] Error 1 Solaris 10, x86_64, GNU C 4.7.1, 64-bit Solaris 10, sparc, GNU C 4.7.1, 32-bit Solaris 10, sparc, GNU C 4.7.1, 64-bit --------------------------------------- tyr mpich-3.0.2-SunOS.x86_64.64_gcc 195 tail log.make.SunOS.x86_64.64_gcc CXX src/binding/cxx/initcxx.lo CXXLD lib/libmpichcxx.la ld: fatal: file libmpichcxx.so.10: open failed: No such file or directory ld: fatal: file processing errors. No output written to lib/.libs/libmpichcxx.so.10.0.2 collect2: error: ld returned 1 exit status make[2]: *** [lib/libmpichcxx.la] Error 1 Kind regards Siegmar
participants (1)
Siegmar Gross
