Re: [mpich-discuss] Problems with running make
I am running centos on two of these, sargeant and constable, and RHEL on the third, gainsborough. By runtime libraries, do you mean for the three compilers included, ie gcc, fortran77 and fortran90? Please use one syllable words, I am the edge of my understanding :-(. Thanks Ron On 2/03/2014 22:55, Reuti wrote:
Am 02.03.2014 um 13:20 schrieb Ron Palmer:
Gus, Reuti, Rajeev and others, I do have mpif77 and mpif90 in mpi/bin, so I conclude that it has compiled ok.
I have checked reuti's suggestions, indicating that the environment is ok. I had added 'PATH=/my/mpi/bin:$PATH' to each of the .bashrc files (for the user I am running on all three)
I am using the same username on all three computers - is that ok?
I have installed MPI on to a NFS drive, all accessing the same; 'which' confirms. Are there any libraries that needs to be installed elsewhere? do need to run make install as root? No.
I have added the 'LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:/my/mpi/lib', though made no difference. (should those "{" and "}" be included? I entered it exactly like I have typed)
I have mpicc the cpi program as suggested by Gus and tried it, as well as the originally provided cpi (part of the downloaded mpi) which I called cpi_orig, see the screen shot below. It looks like there is an issue with libgfortran.so.3... Yep.
Unless you build static applications, the runtime libraries (of the compiler) need to be available on all machines.
There should be package with the runtime libraries in your Linux distribution.
-- Reuti
Perhaps I have not got the various compilers installed correctly? I would appreciate if someone could give me a suggestion on how to properly remove and re-install these (and select the correct ones).
By the way, in the runs of cpi below, I reduced the number of cores to be used on the first pc listed in the machinefile, from 8 to 4, in the case there was an issue with the 9th one. As can be seen, it is the first node (or core) on a remote computer where the problems start to be listed which is node 5 in this case...
If I run cpi on only one computer, it works. And yes, hostname works even if all computers are included in the machinefile.
Clear as mud, hey? Thanks for your help.
participants (1)
Ron Palmer
