Re: [mpich-discuss] Error in compiling MPICH on Mac desktop
You will need to add '-Wa,-q' for CFLAGS and CXXFLAGS for gcc* on Yosemite and above. This will use the clang assembler. (See man as) <plug>The MacPorts mpich package does this automatically when needed.</plug> - Eric On Fri, Oct 30, 2015 at 10:13 AM, Rob Latham <[email protected]> wrote:
On 10/28/2015 12:46 PM, Ghosh, Debojyoti wrote:
I am getting a compilation error while trying to compile MPICH on my Mac desktop. I installed the latest GNU compilers using Homebrew.
gcc -v Using built-in specs. COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/local/Cellar/gcc/5.2.0/libexec/gcc/x86_64-apple-darwin14.5.0/5.2.0/lto-wrapper Target: x86_64-apple-darwin14.5.0 Configured with: ../configure --build=x86_64-apple-darwin14.5.0 --prefix=/usr/local/Cellar/gcc/5.2.0 --libdir=/usr/local/Cellar/gcc/5.2.0/lib/gcc/5 --enable-languages=c,c++,objc,obj-c++,fortran --program-suffix=-5 --with-gmp=/usr/local/opt/gmp --with-mpfr=/usr/local/opt/mpfr --with-mpc=/usr/local/opt/libmpc --with-isl=/usr/local/opt/isl --with-system-zlib --enable-libstdcxx-time=yes --enable-stage1-checking --enable-checking=release --enable-lto --with-build-config=bootstrap-debug --disable-werror --with-pkgversion='Homebrew gcc 5.2.0' --with-bugurl=https://github.com/Homebrew/homebrew/issues --enable-plugin --disable-nls --enable-multilib Thread model: posix gcc version 5.2.0 (Homebrew gcc 5.2.0)
We test with gcc-5.2 on our mac build bots, so it's definitely possible.
I am getting the following error while compiling MPICH: CC src/mpltrmem.lo /var/folders/qf/q3tp7kgn0gz6qj5_c2nr4qqm001qq3/T//ccyirdXM.s:491:suffix or operands invalid for `movq' /var/folders/qf/q3tp7kgn0gz6qj5_c2nr4qqm001qq3/T//ccyirdXM.s:495:suffix or operands invalid for `movq' make[2]: *** [src/mpltrmem.lo] Error 1 make[1]: *** [all-recursive] Error 1 make: *** [all] Error 2
When the assembler is suspicous ('movq') then it sure seems like there's a toolchain mismatch.
Does this bug report from libressl sound like your environment? https://github.com/libressl-portable/portable/issues/121
==rob
-- Rob Latham Mathematics and Computer Science Division Argonne National Lab, IL USA _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Eric A. Borisch
