Re: [mpich-discuss] how to decide master node in mpi cluster node.
Good Morning,Sir I think in my project i need to use job scheduler to submit programs to our MPI cluster nodes.Sir,can you please explain me which job scheduler i need to use and how to configure job scheduler. please can you tell me how to configure mpi cluster in ubuntu 12.04. Thanks You,Sir On Fri, Jan 24, 2014 at 11:05 PM, Wesley Bland <[email protected]> wrote:
First, take a look at the documentation that comes with MPICH. There should be a couple of PDFs in your distribution that provide an installation and usage guide. If you installed your package with a package manager and didn’t receive the documentation, you can get it at the website (www.mpich.org).
As for which node is the “master” and which is the “slave”, there isn’t really such a notion in MPI. The only node that is special is the one where you launch your job. That is just determine by where you are logged in at the time. If you have two hosts (host1, host2), and you are logged into host1, you’d launch your job using something like:
mpiexec -host host1,host2 -n 2 ./myApp
That would launch on both hosts.
I’d highly recommend reading through the documentation provided to get more details about how to set everything up and then ask another question here if something is still unclear.
Thanks, Wesley
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Bhimashankar Dhappadhule
