Re: [mpich-discuss] MPI_init very slow with more than 3 nodes
Hello. The network guys have reviewed the logs of the switches and have found no problems. I have removed the nfs server from the machine file and with two working nodes the delays have appeared. Todays delays have been of 4 minutes to over an hour. The attachment contains an excerpt from syslog that has appeared several times on a node when the delay was large. I don't know if that can help. Bixente. Pavan Balaji <[email protected]> escribió:
Try to ssh between the nodes and see how long it takes. It might give some hint on what’s going on.
— Pavan
On Nov 29, 2013, at 5:21 AM, Bixente BODO GOMEZ <[email protected]> wrote:
Hi.
In the attachment I send the tests I've done. Yesterday I had to wait 20 minutes; now only 4 or 6. I will ask about the network.
It is possible there’s something really slow on your network. Just to eliminate MPI_INIT as a possible cause, can you try a non-MPI program: maybe /bin/true or /bin/hostname?
% mpiexec -f fila5 -np 8 /bin/true
— Pavan
On Nov 28, 2013, at 8:10 AM, Bixente BODO GOMEZ <[email protected]> wrote:
Goods.
I'm testing a mpich cluster (3.0.4) with 7 nodes quad core, Ubuntu 12.04. The master has the home directory and the nodes get it by nfs. I have change RPCNFSDCOUN from 8 to 64.
The programs go fine with master and ONE of the other nodes, but when I start them with more nodes, MPI_Init (I think so) takes long time (~20 minutes). At these time in all nodes there is many network (read and write) and master's hard disk activity. For exemple:
mpiu@u105251:~$ date; mpirun -f fila5 -np 8 test/hello; date mié nov 27 15:17:29 CET 2013 Hola desde el procesador u105251. 0 de 8 Hola desde el procesador u105251. 1 de 8 Hola desde el procesador u105251. 2 de 8 Hola desde el procesador u105251. 3 de 8 Hola desde el procesador u103972. 4 de 8 Hola desde el procesador u103972. 5 de 8 Hola desde el procesador u103972. 6 de 8 Hola desde el procesador u103972. 7 de 8 mié nov 27 15:17:30 CET 2013 mpiu@u105251:~$ date; mpirun -f fila5 -np 16 test/hello; date mié nov 27 15:17:39 CET 2013 Hola desde el procesador u105251. 2 de 16 Hola desde el procesador u105251. 0 de 16 Hola desde el procesador u105251. 1 de 16 Hola desde el procesador u105251. 3 de 16 Hola desde el procesador u103972. 4 de 16 Hola desde el procesador u103950. 8 de 16 Hola desde el procesador u103976.12 de 16 Hola desde el procesador u103972. 5 de 16 Hola desde el procesador u103950. 9 de 16 Hola desde el procesador u103976.13 de 16 Hola desde el procesador u103972. 7 de 16 Hola desde el procesador u103950.10 de 16 Hola desde el procesador u103976.14 de 16 Hola desde el procesador u103972. 6 de 16 Hola desde el procesador u103950.11 de 16 Hola desde el procesador u103976.15 de 16 mié nov 27 15:36:18 CET 2013 mpiu@u105251:~$
When the programs start, i.e. since the first C instrucction, they run fine. For that I think that the problem is MPI_init
Anybody kowns why? Thank.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
<test.txt>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Bixente BODO GOMEZ
