Re: [mpich-discuss] Re : MPI I/O vs Sequential I/O
megabytes, gigabytes. On Mar 20, 2013, at 6:13 PM, Muhammad Zulfikar Handana wrote:
exactly how big the files are great for use on a comparison of MPI I / O?
thank a lot for your attention
handana
fwrite() does buffered I/O, which will perform better for small writes. A better comparison would be to use write(), which is what MPI-IO uses internally.
Rajeev
On Mar 18, 2013, at 3:49 PM, Muhammad Zulfikar Handana wrote:
hello, i have some questions about MPI-I/O.
1) when i trying execute my program using MPI-I/O. why when iam execute with 1 proses, execute time more good than when iam execute with 2 proses. am i wrong? this is my source code. MPI_File_open (MPI_COMM_WORLD, file_akhir, MPI_MODE_CREATE | MPI_MODE_WRONLY, MPI_INFO_NULL, &hasil); int jumlah1 = (((block-1)*16)+pad); int jumlah = jumlah1 / size;
MPI_File_set_view(hasil, rank * jumlah * sizeof(char),MPI_CHAR, MPI_CHAR, "native", MPI_INFO_NULL); MPI_File_write (hasil, output, jumlah1, MPI_CHAR, MPI_STATUS_IGNORE);
MPI_File_close(&hasil);
2) and after that i have compared that source using MPI - I/O and with sequential I/O, apparently, sequential i / o is better than the parallel i / o. how it could be happen? this is my sequential source. if (rank==0) {
hasil = fopen (file_akhir, "wb"); int test = (((block-1)*16)+pad); fwrite (output, sizeof(char), test, hasil ); fclose (hasil); }
thanks a lot for your attention
discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Rajeev Thakur
