Re: [mpich-discuss] installation failed
Anyways, I think the answer to this problem would be to trick autogen into thinking my version of autoconf is ok. I don't quite know how to do it, what I have got to change in which sh script and how (I have no editor for now) On Wed, Apr 22, 2015 at 11:13 PM, Leo Kameni <[email protected]> wrote:
mmm ok oh well, when you have made the alias error change in the master file along with the autogen config so the user does not have to do it please let me know. It should not be such a hassle to build on windows under cygwin I am sure. Thanks guys
On Wed, Apr 22, 2015 at 11:11 PM, Seo, Sangmin <[email protected]> wrote:
Thanks for trying MPICH on the Windows platform.
However, due to lack of developer resources, MPICH no longer supports the Windows platform. Please refer to our FAQ for more information:
http://wiki.mpich.org/mpich/index.php/Frequently_Asked_Questions#Q:_Why_can....
If you want to use MPI on the Windows platform, we recommend you use Microsoft MPI, which can be found here: http://msdn.microsoft.com/en-us/library/bb524831(v=vs.85).aspx
Thanks, Sangmin
On Apr 22, 2015, at 5:05 PM, Leo Kameni <[email protected]> wrote:
I sometimes get this error as well from autogen.sh
#################################### ## Replicating confdb (and similar) ####################################
syncing 'src/mpl' --> 'src/pm/hydra/mpl' syncing 'confdb' --> 'src/mpi/romio/confdb' syncing 'confdb' --> 'src/mpl/confdb' ./autogen.sh: line 77: 4292 Segmentation fault cp -pPR "$srcdir" "$destdir" syncing 'confdb' --> 'src/pm/hydra/confdb' syncing 'confdb' --> 'src/pm/hydra/mpl/confdb' syncing 'confdb' --> 'test/mpi/confdb' ===> ERROR: expected to find 'aclocal_cc.m4' in 'src/mpl/confdb'
On Wed, Apr 22, 2015 at 10:49 PM, Leo Kameni <[email protected]
wrote:
Ok I see. I think it might not be able to see "libtooklize" because I could not find it in cygwin repositories. Just libtool, which is a dll
On Wed, Apr 22, 2015 at 10:40 PM, Seo, Sangmin <[email protected]> wrote:
I don’t know where you installed your autotools, but I think https://www.cygwin.com/ml/cygwin/2002-01/msg00198.html would be helpful.
— Sangmin
On Apr 22, 2015, at 4:35 PM, Leo Kameni <[email protected]> wrote:
Hi, If I type "which autoconf" it returns "no autoconf in.." If I type "which autoconf-2.69" it returns "usr/bin/autoconf-2.69". i think the autogen.sh file should be change so that I can use my version but I dont know how to edit it. I dont have a txt editor handy, can you do it at all and post it in git?
On Wed, Apr 22, 2015 at 10:13 PM, Leo Kameni < [email protected]> wrote:
what do you mean by my PATH? Also do I type in cygwin “which autoconf? thanks
On Wed, Apr 22, 2015 at 10:12 PM, Seo, Sangmin <[email protected]> wrote:
Can you confirm that your PATH includes the path for autotools? And, can you try “which automake”, “which autoconf”, and “which libtool” to see whether you are using autotools that you installed?
— Sangmin
On Apr 22, 2015, at 4:07 PM, Leo Kameni <[email protected]> wrote:
Hi, do autogen now somehow see that all the autotools are in the same directory, but it says I have an oldversion of autoconf, whereas my version is 2.69 and came package with 2.13. I deleted files with extension -2.13 in the bin folder of cygwin but autogen still says my version is out of date. Can you help at all?
On Wed, Apr 22, 2015 at 7:50 PM, Leo Kameni < [email protected]> wrote:
Hi Sangmin, i am running into further trouble. The autogen.sh bash command wont work. I have installed autoconf automake and libtool through cygwin and autogen.sh says theyre not in the same location but I dont really know the location or what that means and which files need to be in the same location exactly. Can you help?
On Wed, Apr 22, 2015 at 6:57 PM, Seo, Sangmin <[email protected]> wrote:
Hi Leo,
The fix for the alias problem has been pushed to the MPICH master. You can try the latest copy of MPICH. Please refer to https://wiki.mpich.org/mpich/index.php/Getting_And_Building_MPICH for checkout.
Regards, Sangmin
On Apr 22, 2015, at 8:45 AM, Leo Kameni < [email protected]> wrote:
Hi seo, I am using cygwin so it should have been ok I think. When will you fix the error so I can try again please thanks. On 22 Apr 2015 14:43, "Seo, Sangmin" <[email protected]> wrote:
Hi Leo,
As Huiwei mentioned in another email, MPICH no longer supports the Windows platform. However, the error message in your m.txt is valid. We will fix the alias cycle errors.
Thanks, Sangmin
On Apr 22, 2015, at 5:12 AM, Leo Kameni < [email protected]> wrote:
Hi, My installation on my 32 bits windows machine under cygwin failed, I am attaching all log files. The m.txt file reported no issues, so I am surprised it failed. I have installed both gcc-core and gcc latest version from cygwin would that be an issue?
<c.txt><config.log><m.txt>_______________________________________________
discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Leo Kameni
