Re: [mpich-discuss] Generalized request classes
One more thing. If the receive buffers can be allocated before hand to be large enough, you can simply post a receive of a large size. It doesn't have to match the send size. It can be larger (not smaller). On Aug 5, 2013, at 12:08 PM, Jed Brown wrote:
Rajeev Thakur <[email protected]> writes:
If the sizes of messages are that unknown, you can also try MPI one-sided communication.
I'd have thought the reason to use Iprobe was that the receive buffers could not be allocated in advance, in which case one-sided puts don't buy you anything and gets require the sizes and addresses to be sent somehow.
On Aug 5, 2013, at 9:48 AM, Matthieu Dorier wrote:
For the Iprob, the case I'm considering is indeed the one where a process has to do non-blocking sends and non-blocking receives of undefined lengths; I ended up with two options: 1) using a busy loop that does an MPI_Testany for the list of send requests and a series of MPI_Iprob for a list of (source,tag) pairs, or 2) split each receive operation into one Irecv of known length 1 MPI_INT that gives the size of the next message, then a blocking MPI_Recv of this size. No busy loop needed by one extra (yet small) message.
A third option is to MPI_Probe on MPI_ANY_SOURCE for the expected number of receives, allocating your receive buffer when you know the size. This assumes you can use a single tag for the round of communication.
participants (1)
Rajeev Thakur
