Fwd: MPI_T_ERR_ ... error codes for FORTRAN
Hi, Mike, From MPI-3.0 A.1.1., I can not see it requires all constants are valid in C and FORTRAN. Instead, in 14.3, it says "Since the MPI tool information interface primarily focuses on tools and support libraries, MPI implementations are only required to provide C bindings for functions introduced in this section." And in MPICH's f08 bindings, it is the same (i.e. no support of MPI-T). --Junchao Zhang On Tue, Sep 30, 2014 at 10:39 AM, Michael L. Stokes <[email protected]> wrote:
On 09/30/2014 10:36 AM, [email protected] wrote:
According to the MPI-3.0 spec (A.1.1), C and FORTRAN constants are supposed to be shared (with noted exceptions). These include the MPI_T_ERR_ ... error codes. But from what I can determine, none of the MPI_T_ERR_ error codes seem to compile under the mpif77 compiler (intel) using MPICH 3.1.2. So I post the following questions:
1) Am i interpreting the specs correctly in that all constants (error codes in this instance) are valid in C and FORTRAN?
2) Is the behavior I'm seeing correct given the current intel compiler and version of MPICH? The snippet of code I'm using is the following. Here I'm using a perl script hereto document to write FORTRAN code where $target is any of the MPI error codes, and $ext is 'f' in this case.
PROGRAM ERRORCODE IMPLICIT NONE INCLUDE "mpif.h"
IF( $target.ge.MPI_SUCCESS .and. + $target.le.MPI_ERR_LASTCODE) THEN WRITE(6,1) 1 FORMAT('$ext "$target" +is verified ') ELSE WRITE(6,2) 2 FORMAT('$ext "$target" +is not verified ') ENDIF
CALL EXIT(0) END PROGRAM ERRORCODE
3) Will this behavior change under the f08 FORTRAN bindings?
Thanks Mike
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Junchao Zhang
