[Fwd: Re: Parallel Interface philosophical comments]
[Forwarding for archival] -------- Original Message -------- Subject: Re: Parallel Interface philosophical comments Date: Tue, 23 Oct 2007 16:20:27 -0400 From: Mark Shephard <[email protected]> To: Tim Tautges <[email protected]> CC: Onkar Sahni <[email protected]>, "Devine, Karen D." <[email protected]>, Kenneth Jansen <[email protected]>, Ting Xie <[email protected]>, Vitus Leung <[email protected]>, Carl Ollivier-Gooch <[email protected]>, "Lori A. Diachin" <[email protected]>, Jason Kraftcheck <[email protected]>, "Knupp, Patrick" <[email protected]> References: <C338DFBB.B5CD%[email protected]> <[email protected]> <[email protected]> <[email protected]> Tim, I was under the impression at the bootcamp that we agreed that those that have operational parallel capabilities support it through either reverse classification (via mesh sets) or classification and that we would support both approaches through iPart. However, you last couple of emails appear to go back to the old argument of we must do the minimal thing and since meshsets (reverse classification) are in there that is the only way. By the way, if I understand correctly our existing data-model has the ability to support reverse classification (meshsets) and classification through iRel, so should the parallel model. Yes, that means more functions than only one or the other way, but both approaches exist. (In addition, I still do not equate functionality and data model - it someone meets the functionality I really do not give a crap about their data model.) There are a number of groups that use classification as the primary mode of interaction for doing things similar to how the RPI group does. Just as we would not want you to have redo all your parallel work to do things strictly from a classification perspective, we do not expect that the ITAPS parallel interface will require RPI to re-do all its parallel adaptive work (years worth of work dating back to the mid-90's when we were the first to do it) that is being used for SciDAC applications to fit with a specific one way of doing things. By the way, some feel the classification is a simple and powerful way to do things and mesh sets are actually substantial extra overhead to a well defined model of using classification. In my experience, I would love to have both classification and reverse classification at all times, since depending on the question being asked, one is a faster way to answer it. However, due to the extra data and headache of keeping things correctly set, most I know tend to focus on one and use the other temporary manner when its advantageous. Mark Tim Tautges wrote:
Onkar Sahni wrote:
Hi all,
Here are some of my questions and comments on ITAPS parallel interface:
1) Is there a difference between "instance" and "handle" in ITAPS terminology (or are there any definition for these)? (I may have missed it if this was resolved/defined in previous ITAPS interfaces like iMesh).
We use the generic term "handle" as an identifier for entities, entity sets, the interface itself, and tags. In our C headers, these are typedef'd to void*. There are also iterators, which we haven't really called handles, but could be referred to that way.
2) For situations where we want to support multi-parts per processor/process: (a) How do we want to distinguish between processor/process level functionalities against part level ones (keeping user- and implementation-convenience and efficiency in mind)? Ones which would fall under processor level are, like list of parts on processor, MPI_Rank etc., whereas ones which would fall under part level are, like neighboring parts (not procs.) etc. Further, there could be ones where users wants to get/iterate mesh entities (and get adjacencies) at a processor and/or part level.
Processor-level queries are on the iMesh instance, part-level queries are on the entity set representing the part. Our iterator functions operate on both (with processor-level queries simply using the root set).
(b) Assuming a part-handle is supported, how can user/application get access to it (say on a processor where part resides)? Basically will there be a way to directly access the part-handle (like part iterator at iProcParts level) or user has to access it through tags/tag names, in which case user has to figure out what is the tag/tag name for a particular part (and who defines these tags/tag names).
I advocate having both: a conventional tag given to parts, so that you can find sets that are parts by looking for sets with that tag; and also having a convenience function (as part of the parallel extensions to iMesh) which returns all the parts in the given instance (i.e. on the processor). Note an important capability here for this function is to pass in an optional tag name/handle indicating the partition you're asking about. That allows multiple partitions to co-exist, which is important for some applications.
3) How general we want to be in interface for different data models/implementations (as in future we may want to incorporate/fit other implementations), especially between serial and parallel data. Two possibilities for data models I can think of are: (a) one (serial) data model is enhanced to store parallel information and (b) serial one is supplemented by a separate parallel one to support parallel functionalities (in possibility (b) all parallel-specific information is stored in a separate data to serial-specific data). We could design interface that would fit both possibilities, this is the reason why we included iPartMesh (section 3.4) level functions which are specific to parallel functionalities in mesh (and passing handle to serial data in these interface will not work for second possibility (b)). I do not know how much relevant is this.
I think it's very important to put the parallel data into our existing data models, or extend the data model if that can't be done (which I doubt, since I've already embedded this information in our current data model). This is important because it allows us to use current tools to examine parallel data. Note also that one may sometimes be examining parallel data in a serial environment (e.g. running a partitioner in serial), so we shouldn't restrict accessing parallel data to a parallel environment.
- tim
Let me know if you have questions.
Vitus, due to above questions I did not respond to your comments. I do not know if above questions and comments make things clear. If you still have anything specific please let us know.
Karen, Is there a way to create an email list for this subcommittee as if we want to add (and remove) people (and it will keep record of all the messages). I have added Ting in this response as she is also working on this stuff from RPI side.
Thanks, Onkar
Hi all, I'd like to re-iterate what I think should be the general behavior of functions in the parallel interface. IMO, we should take advantage of the simple yet powerful data model we already have for iMesh. That means using mesh sets for things which are obviously sets, and using the functions which already exist for accessing data in those sets. I think it does make sense in certain cases to make convenience functions in the parallel interface for accessing e.g. all the sets which represent parts of a partition, on a current processor or globally, but I think we should minimize these. Based on the general behavior described above, I think many of the functions proposed for global ids and parts/partitions already exist in iMesh. For example, iPart_getGlobalID, iPart_createGlobalID, iProcParts_getPartIdArrOnProc, iProcParts iterator functions, etc.
- tim
-- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone: (608) 263-8485 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
-- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3 Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone: (608) 263-8485 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
participants (1)
Tim Tautges
