Hi Vitus and all, I went through both tutorials this morning and overall think they're quite nice. I like that you provide the basics here in the second exercise - it's a very nice bridge between Hello and Smooth. I have a few minor notes (below). As a general comment to everyone - do we have any tutorial exercises that aren't in C++? I've gone through Hello, Load Balance and Smooth so far and I'm worried we'll give folks the wrong impression.. I see a .c file in the Hello directory -- would it be hard to add a fortran hello example? Lori Tutorial 1: Exercise 2: It's not clear to me where the MPI communicator is initialized in the test file? I assume it's COMM_WORLD, but you refer to 'initialized above' and I don't see it. I assume it's in the Init function, but it might be helpful to make it more explicit Exercise 3: Remind users how to get a string length; not all users will be c++ savy. In general it's not always clear to me why I'm doing something, getting the parts, getting various handles, etc - is it needed for Zoltan? If you can, it would be useful to add a sentence to the beginning of each exercise giving a bit of motivation for why I need to call this function. It will help folks think through it themselves later.. Tutorial 2: Might prefer to have different test file names in tutorial 1 and tutorial 2.... Actually, rather than switching files/directories, you could keep them all part of a single tutorial and just use the #define trick that Karen used in Hello. Is .vtu a vtk format? I'm not familiar with it and was surprised to see .vtu's... you might want to comment on what to expect in the notes for Exercise 1 ~
Lori (and Karen), Did we decided on time distribution for hands-on part of tutorial? As far as I remember we decided on order of things in hands-on part but it would be good to get an idea of time-length for each hands-on example/exercise. Thanks, Onkar
Hi Onkar, The original thinking was that the hands-on sessions would be 'work at your pace' so I didn't think we needed a time distribution (so we haven't decided on one). That said, I've been thinking about back up plans in case networking is a disaster. I am assuming (and Tim correct me if I'm wrong) that Tim will have a copy of everything on his laptop and we can do a projected presentation of the demos if necessary. It may be a good idea to plan for this in any case as some participants may fail to bring a laptop.. Tim - how likely is the demo suite to be running on your laptop? Lori Onkar Sahni wrote:
Lori (and Karen),
Thanks, Onkar
Assuming the build process was straightforward for all of the pieces, it's probably doable. I'd probably need everyone to point me to a tarball and give me the exact configure/make commands needed to build. That said, I haven't been able to help Jason much with the iMeshP implementation, and doing this might risk us being ready with our implemenation. - tim Lori A. Diachin wrote:
Hi Onkar,
Lori
Onkar Sahni wrote:
Lori (and Karen),
Thanks, Onkar
-- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3 Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone: (608) 263-8485 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
Tim: Do you have time to build and run your example programs (FindAdj, List&Sets, etc.) that are in the tutorial slides? In response to Lori's question, I tried to build the F77 FindAdjacency example, but I didn't succeed. I couldn't find F77 include files in FMDB. I tried using MOAB, but cray pointers in the example appear to be 32-bit while the MOAB libraries that are installed are 64-bit. I don't know enough about cray pointers and fortran to resolve the problem. Even if I had gotten everything compiled, I didn't have an appropriate input file for testing. It would be a good sanity test for us to make sure our examples in the slides compile and run correctly. We could have a separate directory for them in /usr/local/itaps. If I had a working example to use, I think I could convert hello_iMeshP.c to hello_iMeshP.F. Also, the FindAdj example in the slides has the root_set == 0 assumption in at least the C and F77 versions. Thanks! Karen On 11/11/08 11:02 AM, "Lori A. Diachin" <[email protected]> wrote:
Hi Vitus and all,
Lori
Tutorial 1:
Tutorial 2:
Yep, I'll do that. Note to others, we "ratified" the move to the C-based interface based in part on it working out of the box from Fortran. That does take extra work to achieve due to the underscore handling differences on various machines. I think it will look very bad if only one of our interface implementations supports Fortran (like it or not, there are MANY scidac apps implemented in that language, maybe even more than half of them). - tim Devine, Karen D wrote:
Tim:
Thanks! Karen
Hi Vitus and all,
Lori
Tutorial 1:
Tutorial 2:
As per my experience, typically if an implementation supports the functionality as per the specifications, allowing Fortran interface support is a question of appropriate symbol definition for various machines. This is another reason that such things (header files) should come from a central place like ITAPS repository and not from each specific implementation. Thanks, Onkar
- tim
Tim:
Thanks! Karen
Hi Vitus and all,
Lori
Tutorial 1:
Tutorial 2:
On Tue, Nov 11, 2008 at 1:02 PM, Lori A. Diachin <[email protected]> wrote:
Hi Vitus and all,
Lori
Tutorial 1:
Tutorial 2:
FronTier tutorial uses only C, however it compiles with g++. Changing to gcc won't be a problem if I pull my hair out for a day or so setting up the proper "extern 'C'" directives in FronTier so that linkage goes correctly. Is this desirable? -- ~Ryan Kaufman
Hi Ryan, It's probably not critical to reconfigure to use gcc. I'm going to work through your example now.. I'll let you know if I find any issues. Lori Ryan Kaufman wrote:
Hi Vitus and all,
Lori
Tutorial 1:
Tutorial 2:
Lori and all, Okay, I have incorporated Lori's suggestions. Vitus On Tue, 2008-11-11 at 11:02 -0700, Lori A. Diachin wrote:
Hi Vitus and all,
Lori
Tutorial 1:
Tutorial 2:
I got paraview installed in the /usr/local/itaps directory. It seems to be working. Vitus On Tue, 2008-11-11 at 11:02 -0700, Lori A. Diachin wrote:
Hi Vitus and all,
Lori
Tutorial 1:
Tutorial 2:
participants (6)
Devine, Karen D -
Lori A. Diachin -
Onkar Sahni -
Ryan Kaufman -
Tim Tautges -
Vitus Leung
