Re: [mg-rast] Doubt about MG-Rast annotation
Hi, The number discrepancy arises from the use of different databases, the original 209 hits is specific to the SEED subsystem, with 66 hits against the proteins in these organisms. When you perform the organism classification against GenBank, the number of hits is higher because of the greater number of organisms in the GenBank database, and so does the abundance counts. The workbench abundance column of the table gives a better breakdown of the taxonomic counts as compared to the 209 count. This is not very intuitive from the display and we are looking into changing the table to make this more explicit. Regards, Mark ----- Original Message -----
From: "Gustavo B. Gregoracci" <[email protected]> To: "Mark DSouza" <[email protected]> Cc: "MG- Rast" <[email protected]>, "Louisi Oliveira" <[email protected]> Sent: Monday, July 18, 2011 1:03:28 PM Subject: Re: Doubt about MG-Rast annotation Hi there Mark,
Thanks for the reply. So, the metagenome ID is 4465448.3 and its called Forno. The glitch has actually happened in others as well, and I'm only using this one as an example.
I re-checked the numbers and they still don't add. I'm working with Genbank (e-5) for organism classification, and subsystems (e-5) for functional classification, for that matter.
I have 209 hits in this entire metagenome for photosynthesis. If I check the number of photosynthesis hits among the bacterial hits I get 140, while the same for eukaryotic gives me 142 hits. That puzzled me. When I do the opposite, and check the taxonomic composition of just the 209 photosynthesis hits the numbers are even more weirder. I get 245 hits for bacteria and 403 for eukaryotes!
Thanks again for the help, I'm available for any further explanations necessary,
Best regards, Gustavo
Gustavo Bueno Gregoracci -- MSc., Dr. in Microbiology (Genetics and Molecular Biology) Email: [email protected]
-- Pos doc Student Laboratório de Microbiologia (Prof. Fabiano Thompson) Centro de Ciências de Saúde - Instituto de Biologia - UFRJ Tel: +55 (21) 2562-6567
From: Mark DSouza <[email protected]> To: Gustavo B. Gregoracci <[email protected]> Cc: MG- Rast <[email protected]> Sent: Monday, July 18, 2011 1:33 PM Subject: Re: Doubt about MG-Rast annotation
Can you please send us the MG-RAST ID for the dataset where you observed this, we will check into it for you.
-- Regards, Mark D'Souza -- for the MG-RAST team
[email protected] http://metagenomics.anl.gov/
If you need to respond to this email please address it to the mailing-list [email protected]
From: "Gustavo B. Gregoracci" < [email protected] > To: "Mark D'Souza" < [email protected] > Sent: Saturday, July 16, 2011 10:05:14 AM Subject: Doubt about MG-Rast annotation Hello there Mark,
As I was analyzing some metagenomes, I ran into a recurrent problem. I was trying to cross information from taxonomic and functional annotation, and discovered some inconsistencies. I could not figure those out so I’m writing you in the hope that you can help me, since this will affect my analysis.
You see… I wanted to understand the contribution of different phylogenetic groups to a given subsystem. So I got the total number of sequences for the photosynthesis subsystem, for example, which was 209 hits. Then I went into taxonomy and separated all entries identified as eukaryotes, sending them to the workbench. I changed again to functional and checked the total number of eukaryotic hits to photosynthesis, which was 163. So far so good, but I decided to perform the same analysis regarding prokaryotes. Sent all prokaryotic entries to the workbench and changed to functional to see their contribution to photosynthesis as well. I got 174 hits!
How is this possible? If my whole metagenome has 209 hits to a subsystem, how can I have 163 eukaryotic hits within it and 174 prokaryotic hits to the same subsystem? Can sequences be annotated as both eukaryotic and prokaryotic? Cause I was interpreting these categories as mutually exclusive…
Thanks in advance for the help, Looking forward to hear from you,
participants (1)
Mark DSouza
