Q on initializing MOAB iMesh interface
Hi all, Currently in MOAB's iMesh implementation, the class structure looks like: class MBiMesh : public Core {...} It's done this way because the iMesh implementation needs to keep some member data that Core doesn't need. However, it also makes it impossible to construct an iMesh object from an existing Core object. I'd like to change that. What I'd like to do is change MBiMesh from "isA" to "hasA", i.e. to make MBiMesh point to an Interface object. The MBiMesh object would keep track of whether it constructed MOAB or was passed one, so it would know whether it could destroy it in iMesh_dtor. I'd also like to enable the Interface::query_interface method to return an iMesh instance, consistent with other interfaces it already handles. The net effect of all this would that applications could gain access to an iMesh interface on a transient basis, e.g. if they wanted to call a service implemented in iMesh but not MOAB. Does anybody see any problem with this approach, or think I should do it differently? - tim -- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3 Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone: (608) 263-8485 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
Hello, Yes, I think this would be better. It should continue to allow multiple iMesh instances. Also, iGeom implementation in MOAB should be changed in a similar way. Currently only one iGeom instance is possible; a similar class is needed, that contains the global variables defined in iGeom_MOAB.cpp, and a pointer to Core (or MBiMesh?) Thanks, Iulian ----- Original Message -----
- tim
Hmm, good point. The singletons in CGM don't allow multiple of those to exist, but maybe with a C++ version of iGeom multiple ones of those could; or, is this just another form of a multiplexer? - tim On 01/08/2011 03:08 PM, Iulian Grindeanu wrote:
Thanks, Iulian
- tim
participants (2)
Iulian Grindeanu -
Tim Tautges
