r4404 - MOAB/trunk/test/parallel
Author: kraftche Date: 2010-12-22 12:09:40 -0600 (Wed, 22 Dec 2010) New Revision: 4404 Modified: MOAB/trunk/test/parallel/parallel_unit_tests.cpp Log: fix bugs in parallel_unit_tests.cpp (incorrect size, incorrect assumption that global ids are zero-based, etc.) Modified: MOAB/trunk/test/parallel/parallel_unit_tests.cpp =================================================================== --- MOAB/trunk/test/parallel/parallel_unit_tests.cpp 2010-12-21 22:40:24 UTC (rev 4403) +++ MOAB/trunk/test/parallel/parallel_unit_tests.cpp 2010-12-22 18:09:40 UTC (rev 4404) @@ -7,6 +7,7 @@ #include "moab_mpi.h" #include <iostream> #include <algorithm> +#include <map> #include <sstream> #include <assert.h> #if !defined(_MSC_VER) && !defined(__MINGW32__) @@ -1125,12 +1126,12 @@ return MB_SUCCESS; } -bool check_consistent_ids( Interface& mb, - const EntityHandle* entities, - const int* orig_ids, - int num_ents, - const char* singular_name, - const char* plural_name ) +ErrorCode check_consistent_ids( Interface& mb, + const EntityHandle* entities, + const int* orig_ids, + int num_ents, + const char* singular_name, + const char* plural_name ) { ErrorCode rval; int rank, size, ierr; @@ -1141,16 +1142,20 @@ rval = mb.tag_get_handle( GLOBAL_ID_TAG_NAME, id_tag ); CHKERR(rval); std::vector<int> new_ids(num_ents); rval = mb.tag_get_data( id_tag, entities, num_ents, &new_ids[0] ); CHKERR(rval); - bool valid = true; - for (int i = 0; i < num_ents; ++i) - if (new_ids[i] < 0 || new_ids[i] >= num_ents*size) { - std::cerr << "ID out of bounds on proc " << rank - << " : " << new_ids[i] << " not in [0," << num_ents*size-1 - << "]" << std::endl; - valid = false; - } - if (!valid) - return false; + // This test is wrong. a) The caller can select a start ID so there's + // no guarantee that the IDs will be in any specific range and b) There + // is no reason to expect the global number of entities to be num_ents*size + // if there are any shared entities. J.Kraftcheck 2010-12-22 + //rval = MB_SUCCESS; + //for (int i = 0; i < num_ents; ++i)
participants (1)
kraftche@cae.wisc.edu
