r5537 - in MOAB/trunk: src src/io tools
Author: tautges Date: 2012-05-31 19:03:30 -0500 (Thu, 31 May 2012) New Revision: 5537 Modified: MOAB/trunk/src/Core.cpp MOAB/trunk/src/io/WriteHDF5.cpp MOAB/trunk/tools/convert.cpp Log: - when running mbconvert with both -M and -P or -p options, turn off parallel writing option (since that's what's implied by -P or -p) - write a meaningful error message when serial hdf5 writer fails due to not implementing parallel open file - make default writer parallel hdf5 if it's enabled Modified: MOAB/trunk/src/Core.cpp =================================================================== --- MOAB/trunk/src/Core.cpp 2012-05-31 22:31:51 UTC (rev 5536) +++ MOAB/trunk/src/Core.cpp 2012-06-01 00:03:30 UTC (rev 5537) @@ -66,8 +66,13 @@ #endif #ifdef HDF5_FILE -# include "WriteHDF5.hpp" - typedef moab::WriteHDF5 DefaultWriter; +# ifdef HDF5_PARALLEL +# include "WriteHDF5Parallel.hpp" + typedef moab::WriteHDF5Parallel DefaultWriter; +# else +# include "WriteHDF5.hpp" + typedef moab::WriteHDF5 DefaultWriter; +# endif #elif defined(NETCDF_FILE) # include "WriteNCDF.hpp" typedef moab::WriteNCDF DefaultWriter; Modified: MOAB/trunk/src/io/WriteHDF5.cpp =================================================================== --- MOAB/trunk/src/io/WriteHDF5.cpp 2012-05-31 22:31:51 UTC (rev 5536) +++ MOAB/trunk/src/io/WriteHDF5.cpp 2012-06-01 00:03:30 UTC (rev 5537) @@ -2520,6 +2520,7 @@ int, double* ) { + writeUtil->report_error("WriteHDF5 does not support parallel writing.\n"); return error(MB_NOT_IMPLEMENTED); } Modified: MOAB/trunk/tools/convert.cpp =================================================================== --- MOAB/trunk/tools/convert.cpp 2012-05-31 22:31:51 UTC (rev 5536) +++ MOAB/trunk/tools/convert.cpp 2012-06-01 00:03:30 UTC (rev 5537) @@ -274,7 +274,8 @@ if (parallel) { read_opts.push_back("PARALLEL=READ_PART"); read_opts.push_back("PARTITION=PARALLEL_PARTITION"); - write_opts.push_back("PARALLEL=WRITE_PART"); + if (!append_rank && !percent_rank_subst) + write_opts.push_back("PARALLEL=WRITE_PART"); } if (resolve_shared) read_opts.push_back("PARALLEL_RESOLVE_SHARED_ENTS"); if (exchange_ghosts) read_opts.push_back("PARALLEL_GHOSTS=3.0.1");
participants (1)
tautges@mcs.anl.gov
