Author: kraftche Date: 2009-02-27 11:35:12 -0600 (Fri, 27 Feb 2009) New Revision: 2669 Modified: MOAB/trunk/Makefile.am MOAB/trunk/tools/iMesh/Makefile.am Log: fix 'make dist' Modified: MOAB/trunk/Makefile.am =================================================================== --- MOAB/trunk/Makefile.am 2009-02-27 17:30:52 UTC (rev 2668) +++ MOAB/trunk/Makefile.am 2009-02-27 17:35:12 UTC (rev 2669) @@ -359,7 +359,7 @@ mbcn_test_SOURCES = MBCN.hpp MBCN.cpp mbcn_test.cc mbcn_test_CPPFLAGS = -DSRCDIR=$(srcdir) # define anything to work around build issue -EXTRA_DIST = test.cub quad9.cub hex27.cub +EXTRA_DIST = test.cub # Other files to clean up (e.g. output from tests) MOSTLYCLEANFILES = dumped_acis.sat tree.h5m Modified: MOAB/trunk/tools/iMesh/Makefile.am =================================================================== --- MOAB/trunk/tools/iMesh/Makefile.am 2009-02-27 17:30:52 UTC (rev 2668) +++ MOAB/trunk/tools/iMesh/Makefile.am 2009-02-27 17:35:12 UTC (rev 2669) @@ -15,7 +15,7 @@ # stuff for c test program check_PROGRAMS = testc_cbind -EXTRA_DIST = brick.vtk +EXTRA_DIST = brick.vtk quad9.cub libiMesh_la_SOURCES = \ iMesh_MOAB.cpp \
participants (1)
kraftche@cae.wisc.edu
