Author: tautges Date: 2012-06-01 14:37:53 -0500 (Fri, 01 Jun 2012) New Revision: 5539 Modified: MOAB/trunk/src/parallel/ParallelComm.cpp Log: Some misc whitespace changes. Modified: MOAB/trunk/src/parallel/ParallelComm.cpp =================================================================== --- MOAB/trunk/src/parallel/ParallelComm.cpp 2012-06-01 15:12:59 UTC (rev 5538) +++ MOAB/trunk/src/parallel/ParallelComm.cpp 2012-06-01 19:37:53 UTC (rev 5539) @@ -54,19 +54,19 @@ std::string __PACK_string, __UNPACK_string; #ifdef DEBUG_PACKING_TIMES -# define PC(n, m) { \ +# define PC(n, m) { \ if (__PACK_num == (unsigned int)n && __PACK_string == m) __PACK_count++; \ - else { \ - if (__PACK_count > 1) std::cerr << " (" << __PACK_count << "x)"; \ - __PACK_count = 1; __PACK_string = m; __PACK_num = n; \ - std::cerr << std::endl << "PACK: " << n << m; \ + else { \ + if (__PACK_count > 1) std::cerr << " (" << __PACK_count << "x)"; \ + __PACK_count = 1; __PACK_string = m; __PACK_num = n; \ + std::cerr << std::endl << "PACK: " << n << m; \ }} -# define UPC(n, m) { \ +# define UPC(n, m) { \ if (__UNPACK_num == (unsigned int)n && __UNPACK_string == m) __UNPACK_count++; \ - else { \ + else { \ if (__UNPACK_count > 1) std::cerr << "(" << __UNPACK_count << "x)"; \ - __UNPACK_count = 1; __UNPACK_string = m; __UNPACK_num = n; \ - std::cerr << std::endl << "UNPACK: " << n << m; \ + __UNPACK_count = 1; __UNPACK_string = m; __UNPACK_num = n; \ + std::cerr << std::endl << "UNPACK: " << n << m; \ }} #else # define PC(n, m) @@ -196,16 +196,16 @@ } enum MBMessageTag {MB_MESG_ANY=MPI_ANY_TAG, - MB_MESG_ENTS_ACK, - MB_MESG_ENTS_SIZE, - MB_MESG_ENTS_LARGE, - MB_MESG_REMOTEH_ACK, - MB_MESG_REMOTEH_SIZE, - MB_MESG_REMOTEH_LARGE, - MB_MESG_TAGS_ACK, - MB_MESG_TAGS_SIZE, - MB_MESG_TAGS_LARGE}; - + MB_MESG_ENTS_ACK, + MB_MESG_ENTS_SIZE, + MB_MESG_ENTS_LARGE, + MB_MESG_REMOTEH_ACK,
participants (1)
tautges@mcs.anl.gov
