Re: [MOAB-dev] moab-dev Digest, Vol 86, Issue 21
Hi John I've found that on Linux if you at the cubit/bin directory to your LD_LIBRARY_PATH that fixes that. Try adding the equivalent to the DYLD_LIBRARY_PATH. Thanks Andy On Dec 19, 2015 12:00 PM, <[email protected]> wrote:
Send moab-dev mailing list submissions to [email protected]
To subscribe or unsubscribe via the World Wide Web, visit https://lists.mcs.anl.gov/mailman/listinfo/moab-dev or, via email, send a message with subject or body 'help' to [email protected]
You can reach the person managing the list at [email protected]
When replying, please edit your Subject line so it is more specific than "Re: Contents of moab-dev digest..."
Today's Topics:
1. Is cubit now required by cgma? (JR Cary)
Message: 1 Date: Sat, 19 Dec 2015 06:57:17 -0700 From: JR Cary <[email protected]> To: [email protected] Subject: [MOAB-dev] Is cubit now required by cgma? Message-ID: <[email protected]> Content-Type: text/plain; charset=utf-8; format=flowed
I recently updated cgm and tried building it as I had been, configuring with
'/opt/contrib-clangcxx11/cmake-3.2.2-ser/bin/cmake' -DCMAKE_INSTALL_PREFIX:PATH=/opt/volatile-clangcxx11/cgm-master.r1494-ser -DCMAKE_BUILD_TYPE:STRING=Release -DCMAKE_COLOR_MAKEFILE:BOOL=FALSE -DCMAKE_VERBOSE_MAKEFILE:BOOL=TRUE -DBUILD_WITH_SHARED_RUNTIME:BOOL=TRUE -DCMAKE_C_COMPILER:FILEPATH='/usr/bin/clang' -DCMAKE_CXX_COMPILER:FILEPATH='/usr/bin/clang++' -DCMAKE_Fortran_COMPILER:FILEPATH='/opt/homebrew/bin/gfortran-4.9' -DCMAKE_C_FLAGS:STRING='-fPIC -pipe' -DCMAKE_CXX_FLAGS:STRING='-std=c++11 -stdlib=libc++ -fPIC -pipe' -DCMAKE_Fortran_FLAGS:STRING='-fPIC -pipe'
-DOCE_DIR:PATH='/opt/volatile-clangcxx11/oce-OCE-0.17-txc.r1462-sersh/OCE.framework/Versions/0.17/Resources' /sources/projects/composerall/cgm
The configure worked fine, but the build failed at
/usr/bin/clang++ -std=c++11 -stdlib=libc++ -fPIC -pipe -O3 -DNDEBUG -dynamiclib -Wl,-headerpad_max_install_names -o ../lib/libcubit_util.dylib ...
Undefined symbols for architecture x86_64: "CubitColor::CubitColor(unsigned char, unsigned char, unsigned char, unsigned char)", referenced from: __GLOBAL__sub_I_GfxDebug.cpp in GfxDebug.cpp.o "CubitColor::CubitColor()", referenced from: __GLOBAL__sub_I_GfxDebug.cpp in GfxDebug.cpp.o "CubitEvent::~CubitEvent()", referenced from: CubitCoordinateSystem::~CubitCoordinateSystem() in CubitCoordinateSystem.cpp.o ...
Is CUBIT now required?
Thx...John Cary
PS - looking at geom/CMakeLists.txt, I see that I needed to add -DCGM_OCC:BOOL=ON to pick up OCC/OCE, but that did not help the build.....
_______________________________________________ moab-dev mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/moab-dev
End of moab-dev Digest, Vol 86, Issue 21 ****************************************
participants (1)
Andrew Davis
