Hi all, Is there evidence of MOAB building/running successfully on Windows? If so, are there build instructions somewhere? Thanks, Paul -- -- ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ -- Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://go.wisc.edu/pphw-cal Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu Faculty Director, Advanced Computing Infrastructure ~ http://aci.wisc.edu
Hi Paul, You will need to pursue the CMake route to build MOAB on Windows with MSVC. The Kitware folks (cc'd), have a superbuild script that may make the job easier but I believe the current master may work out of the box, if you don't need MPI. Parallel configuration may require more tweaking. We currently don't test Windows builds here and we probably should at some point. But if you encounter difficulties and have fixes for those, a PR would be much appreciated. Ben/Bob, any other comments wrt Windows builds ? Can we document this process somewhere ? Either updating README or User Guide would be a good place. Or a post in the SIGMA website would do too. Vijay On Wednesday, June 8, 2016, Paul Wilson <[email protected]> wrote:
Hi all,
Thanks, Paul
participants (2)
Paul Wilson -
Vijay S. Mahadevan
