MOAB currently defines the following enum in MBTypes.h: /** Meshset options: properties for meshset creation. * Values are bit flags that may be combined with a bitwise OR (|) */ enum MBEntitySetProperty { MESHSET_TRACK_OWNER = 0x1, /**< create entity to meshset adjacencies */ MESHSET_SET = 0x2, /**< set contents are unique */ MESHSET_ORDERED = 0x4 /**< order of set contents is preserved */ }; and has the following three functions in MBInterface that interact with this enum: MBErrorCode create_meshset(const unsigned int options, MBEntityHandle &ms_handle, int start_id = 0) = 0; MBErrorCode get_meshset_options(const MBEntityHandle ms_handle, unsigned int& options) const = 0; MBErrorCode set_meshset_options(const MBEntityHandle ms_handle, const unsigned int options) = 0; This API is somewhat confusing for two reasons: a) We pass a bitwise-OR of the MBEntitySetProperty values an int, but the latter two are mutually exclusive in the implementation. b) The get/set paradigm for the options is not very convenient (and potentially error prone) because one needs to get the previous options and flip bits to make sure that some property (e.g. tracking) isn't accidentally disabled. For example, doing: set_meshset_options( my_set, MESHSET_SET ) may will remove the MESHSET_TRACK_OWNER property, if it is set. I think that the API would be easier to understand and less error prone if we instead had: enum MBEntitySetStorage { MESHSET_SET, MESHSET_ORDERED }; MBErrorCode create_meshset( MBEntitySetStorage type, MBEntityHandle& ms_handle, bool tracking = false, int start_id = 0 ) = 0; MBErrorCode get_meshset_options( MBEntityHandle ms_handle, MBEntitySetStorage& storage, bool& is_tracking ) = 0; MBErrorCode set_meshset_tracking( MBEntityHandle ms_handle, bool tracking ) = 0; MBErrorCode set_meshset_storage( MBEntityHandle ms_handle, MBEntitySetStorage type ) = 0; Any opinions? - jason
Hi Everyone, Is the MESHSET_SET vs. MESHSET_ORDERED analogous to MBRanges vs. std::vectors? Ranges (and MESHSET_SETS) are ordered by handle and unique. Vectors (and MESHSET_ORDEREDs) are not ordered by handle and preserve duplicates. I would get rid of the MESHSET_SET flag and only use MESHSET_ORDERED and MESHSET_TRACKING. If either of these are not specified, the default behavior would be unordered, not tracking. In my short MOAB career I've thought the MESHSET_SET flag seems unnecessary. Brandon ----- Original Message ---- From: Jason Kraftcheck <[email protected]> To: Tim Tautges <[email protected]> Cc: Developer correspondence for MOAB <[email protected]> Sent: Tue, October 27, 2009 3:59:47 PM Subject: [MOAB-dev] MBInterface API changes for meshsets MOAB currently defines the following enum in MBTypes.h: /** Meshset options: properties for meshset creation. * Values are bit flags that may be combined with a bitwise OR (|) */ enum MBEntitySetProperty { MESHSET_TRACK_OWNER = 0x1, /**< create entity to meshset adjacencies */ MESHSET_SET = 0x2, /**< set contents are unique */ MESHSET_ORDERED = 0x4 /**< order of set contents is preserved */ }; and has the following three functions in MBInterface that interact with this enum: MBErrorCode create_meshset(const unsigned int options, MBEntityHandle &ms_handle, int start_id = 0) = 0; MBErrorCode get_meshset_options(const MBEntityHandle ms_handle, unsigned int& options) const = 0; MBErrorCode set_meshset_options(const MBEntityHandle ms_handle, const unsigned int options) = 0; This API is somewhat confusing for two reasons: a) We pass a bitwise-OR of the MBEntitySetProperty values an int, but the latter two are mutually exclusive in the implementation. b) The get/set paradigm for the options is not very convenient (and potentially error prone) because one needs to get the previous options and flip bits to make sure that some property (e.g. tracking) isn't accidentally disabled. For example, doing: set_meshset_options( my_set, MESHSET_SET ) may will remove the MESHSET_TRACK_OWNER property, if it is set. I think that the API would be easier to understand and less error prone if we instead had: enum MBEntitySetStorage { MESHSET_SET, MESHSET_ORDERED }; MBErrorCode create_meshset( MBEntitySetStorage type, MBEntityHandle& ms_handle, bool tracking = false, int start_id = 0 ) = 0; MBErrorCode get_meshset_options( MBEntityHandle ms_handle, MBEntitySetStorage& storage, bool& is_tracking ) = 0; MBErrorCode set_meshset_tracking( MBEntityHandle ms_handle, bool tracking ) = 0; MBErrorCode set_meshset_storage( MBEntityHandle ms_handle, MBEntitySetStorage type ) = 0; Any opinions? - jason
Any opinions?
- jason
-- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3 Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone: (608) 263-8485 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
participants (3)
Brandon Smith -
Jason Kraftcheck -
Tim Tautges
