Re: [MOAB-dev] gaher entities at root process
Hi Thanks for this. Kind regards, Lukasz From: Vijay S. Mahadevan <[email protected]> Date: Friday, 22 November 2024 at 18:20 To: Lukasz Kaczmarczyk <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: gaher entities at root process Dear Lukasz, Sorry about the delay in responding. I've been swamped with various deadlines, but I have something that you can use. Please look at the branch: vijaysm/example-gather-mesh and under examples/advanced/GatherMeshOnRoot.cpp, it demonstrates how one can use ParallelComm to accumulate entities from different processes on the root. It's what I want to call the equivalent of a MPI_Gather operation: Mesh_Gather. You can add options to move the tags as well; this should be trivial within this infrastructure. Let me know what you think. It is not extensively documented but hopefully, the usage and ideas are straightforward. The one thing that I dislike in this workflow is that you need to perform a local "merge" of entities - especially the shared edge/vertices. I don't exactly see how one can avoid this at the moment. I will submit a PR for that branch and we will get that merged as well. Best, Vijay On Fri, Nov 15, 2024 at 6:35 AM Lukasz Kaczmarczyk <[email protected]> wrote:
Hi Vijay,
Thank you for your response.
I needed to accumulate a subset of the mesh on the root task, on top of its local portion of the mesh. I have the same internal surface distributed across a subset of processors and need to accumulate the root volumes adjacent to it. This is required only temporarily for some topological queries.
I created a minimal working example that is not functioning as expected. I must be making a silly mistake somewhere, but I cannot figure out why it is not working. See the attached file and mesh. The mesh is partitioned for two processes.
mpirun -np 2 ./mwe_send_entities
Regards, Lukasz
From: Vijay S. Mahadevan <[email protected]> Date: Thursday, 14 November 2024 at 15:38 To: Lukasz Kaczmarczyk <[email protected]> Cc: moab-dev <[email protected]> Subject: Re: gaher entities at root process
Hi Lukasz,
Let me understand the context correctly here. Do you want to accumulate some subset of the mesh on the root task, on top of its local piece of the mesh? Or is the motivation to collect the entities on the root to perform some other task on them that only the root process is capable of achieving?
An easier approach, but a bit wasteful, is probably to keep the entire mesh on the zero processors while the rest remains distributed and data from the parts is gathered. That I can make working.,
I would not recommend this, especially since the approach will not scale well with mesh resolution.
Your usage of send_entities/recv_messages looks correct according to the API, but why are you not using recv_entities to be consistent here? Having a MWE will help debug and provide a better solution for this particular workflow for meshes of interest.
In our climate simulations, we handle migration of entire meshes from one set of processes to another set with adaptive repartitioning. These involve communication of entities between processes and I'll see if we can create an example out of that to just send parts of a mesh to the root.
Best, Vijay
On Wed, Nov 13, 2024 at 7:31 PM Lukasz Kaczmarczyk <[email protected]> wrote:
Hi Vijay,
I am looking for advice on how to gather some entities on the zero processor. Is there a good way to do this? I couldn't find a working example for send_entities and recv_messages from pcomm.
However, I am not sure what the best policy is.
What is my mistake:
int to_proc = 0;
Range orig_ents = ents;
bool adjs = false;
bool tags = false;
bool store_remote_handles = false;
bool is_iface = false;
Range final_ents;
int incoming1 = 0;
int incoming2 = 0;
TupleList entprocs;
std::vector<MPI_Request> recv_remoteh_reqs;
bool wait_all = true;
int from_proc = 1;
std::vector<std::vector<EntityHandle>> L1hloc;
std::vector<std::vector<EntityHandle>> L1hrem;
std::vector<std::vector<int>> L1p;
std::vector<EntityHandle> L2hloc;
std::vector<EntityHandle> L2hrem;
std::vector<unsigned int> L2p;
pcomm->recv_messages(
from_proc, store_remote_handles, is_iface, final_ents, incoming1,
incoming2, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, recv_remoteh_reqs);
pcomm->send_entities(to_proc, orig_ents, adjs, tags,
incoming1, incoming2, entprocs,
recv_remoteh_reqs, wait_all);
Kind Regards, Lukasz
participants (1)
Lukasz Kaczmarczyk
