r4422 - in MOAB/trunk: . src/io src/io/mhdf/src
Author: kraftche Date: 2011-01-06 14:55:51 -0600 (Thu, 06 Jan 2011) New Revision: 4422 Modified: MOAB/trunk/configure.ac MOAB/trunk/src/io/ReadHDF5.cpp MOAB/trunk/src/io/mhdf/src/file.c Log: always try to do lockless IO for HDF5 on BlueGene Modified: MOAB/trunk/configure.ac =================================================================== --- MOAB/trunk/configure.ac 2011-01-06 17:26:13 UTC (rev 4421) +++ MOAB/trunk/configure.ac 2011-01-06 20:55:51 UTC (rev 4422) @@ -40,13 +40,13 @@ fi ]) - # Check if platform is BlueGene AC_MSG_CHECKING([if platform is IBM BlueGene]) -FATHOM_TRY_COMPILER_DEFINE([__bg__],[BLUEGENE=yes],[BLUEGENE=no]) -AC_MSG_RESULT([$BLUEGENE]) +FATHOM_TRY_COMPILER_DEFINE([__bg__], + [AM_CPPFLAGS="$AM_CPPFLAGS -DBLUEGENE" + AC_MSG_RESULT([yes])], + [AC_MSG_RESULT([no])]) - AC_CHECK_PROG([ZCAT],[gunzip],[gunzip -c],[]) AC_CHECK_PROG([ZCAT],[gzip],[gzip -cd],[]) AC_CHECK_PROG([ZCAT],[zcat],[zcat],[]) Modified: MOAB/trunk/src/io/ReadHDF5.cpp =================================================================== --- MOAB/trunk/src/io/ReadHDF5.cpp 2011-01-06 17:26:13 UTC (rev 4421) +++ MOAB/trunk/src/io/ReadHDF5.cpp 2011-01-06 20:55:51 UTC (rev 4422) @@ -56,8 +56,19 @@ namespace moab { +/* If defined, coordinates are read in blocked format (all X values before + * Y values before Z values.) If undefined, then all coordinates for a + * given vertex are read at the same time. + */ #undef BLOCKED_COORD_IO +/* If defined, file is opened first by root node only to read summary, + * file is the closed and the summary is broadcast to all nodes, after + * which all nodes open file in parallel to read data. If undefined, + * file is opened once in parallel and all nodes read summary data. + */ +#undef BCAST_SUMMARY + #define READ_HDF5_BUFFER_SIZE (128*1024*1024) #define assert_range( PTR, CNT ) \ @@ -274,6 +285,15 @@ return error(MB_MEMORY_ALLOCATION_FAILED); if (use_mpio || nativeParallel) {
participants (1)
kraftche@cae.wisc.edu
