r4107 - in MOAB/trunk: doc itaps/imesh src src/io src/moab
Author: tautges Date: 2010-08-20 17:54:53 -0500 (Fri, 20 Aug 2010) New Revision: 4107 Modified: MOAB/trunk/doc/metadata_info.doc MOAB/trunk/itaps/imesh/iMesh.h MOAB/trunk/src/Core.cpp MOAB/trunk/src/io/ReadNC.cpp MOAB/trunk/src/io/ReadNC.hpp MOAB/trunk/src/io/WriteCCMIO.cpp MOAB/trunk/src/moab/Interface.hpp Log: io/ReadNC.?pp: adding a bit more NC reader code io/WriteCCMIO.cpp: account for case where no material sets have been created doc/metadata_info.doc: small additions, for CCMIO file metadata and parallel status Core.cpp: changes to allow range-based deletion of entities, for efficiency Interface.hpp: adding \mainpage section to comments Passes make check in serial and parallel. Modified: MOAB/trunk/doc/metadata_info.doc =================================================================== (Binary files differ) Modified: MOAB/trunk/itaps/imesh/iMesh.h =================================================================== --- MOAB/trunk/itaps/imesh/iMesh.h 2010-08-18 21:07:01 UTC (rev 4106) +++ MOAB/trunk/itaps/imesh/iMesh.h 2010-08-20 22:54:53 UTC (rev 4107) @@ -13,7 +13,7 @@ * to this interface, for example mesh smoothing, adaptive mesh refinement, * and parallel mesh support. * - * \section ITAPS Data Model + * \section DataModel Data Model * * The ITAPS interfaces use a data model composed of four basic data types: \n * \em Entity: basic topological entities in a mesh, e.g. vertices, @@ -37,14 +37,14 @@ * types, Entity Type in the iBase_EntityType enumeration, and * Entity Topology in the iMesh_EntityTopology enumeration. * - * \section KTAPS Entity-, Array-, and Iterator-Based Access + * \section Access Entity-, Array-, and Iterator-Based Access * * The iMesh interface provides functions for accessing entities * individually, as arrays of entities, or using iterators. These access * methods have different memory versus execution time tradeoffs, * depending on the implementation. * - * \section LTAPS Lists Passed Through Interface + * \section Lists Lists Passed Through Interface * * Many of the functions in iMesh have arguments corresponding to lists of * objects. In-type arguments for lists consist of a pointer to an array and Modified: MOAB/trunk/src/Core.cpp =================================================================== --- MOAB/trunk/src/Core.cpp 2010-08-18 21:07:01 UTC (rev 4106) +++ MOAB/trunk/src/Core.cpp 2010-08-20 22:54:53 UTC (rev 4107) @@ -2183,6 +2183,7 @@ ErrorCode Core::delete_entities(const Range &range) { ErrorCode result = MB_SUCCESS, temp_result; + Range failed_ents; for (Range::const_reverse_iterator rit = range.rbegin(); rit != range.rend(); rit++) { @@ -2190,6 +2191,7 @@ temp_result = aEntityFactory->notify_delete_entity(*rit); if (MB_SUCCESS != temp_result) { result = temp_result;
participants (1)
tautges@mcs.anl.gov
