commit/MOAB: iulian07: filter out not owned entities, for writing
1 new commit in MOAB: https://bitbucket.org/fathomteam/moab/commits/912e5d377ff3/ Changeset: 912e5d377ff3 Branch: master User: iulian07 Date: 2014-04-30 21:17:09 Summary: filter out not owned entities, for writing modify the test also, as Jayesh needs cleanup Affected #: 2 files diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp index 9072e38..995bf3f 100644 --- a/src/io/NCWriteHelper.cpp +++ b/src/io/NCWriteHelper.cpp @@ -12,6 +12,7 @@ #include "NCWriteMPAS.hpp" #include "moab/WriteUtilIface.hpp" +#include "MBTagConventions.hpp" #include <sstream> @@ -540,8 +541,18 @@ ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names) switch (variableData.entLoc) { case WriteNC::ENTLOCFACE: // Faces + { rval = mbImpl->get_entities_by_dimension(_fileSet, 2, ents); ERRORR(rval, "Can't get entities for faces."); +#ifdef USE_MPI + bool &isParallel = _writeNC->isParallel; + if (isParallel) { + ParallelComm*& myPcomm = _writeNC->myPcomm; + rval = myPcomm->filter_pstatus(ents, PSTATUS_NOT_OWNED, PSTATUS_NOT); + ERRORR(rval, "Can't get filter for owned entities"); + } +#endif + } break; default: ERRORR(MB_FAILURE, "Not implemented yet."); diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp index 7f9df60..54d16d5 100644 --- a/test/io/write_nc.cpp +++ b/test/io/write_nc.cpp @@ -111,11 +111,13 @@ void test_eul_read_write_T() ErrorCode rval = mb.create_meshset(MESHSET_SET, set); CHECK_ERR(rval); - // Load non-set variable T, set variable gw, and the mesh - read_opts += ";DEBUG_IO=0;VARIABLE=T,gw"; + read_opts = "PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1;PARTITION_METHOD=SQIJ;VARIABLE="; rval = mb.load_file(example_eul, &set, read_opts.c_str()); CHECK_ERR(rval); + read_opts = "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=SQIJ;VARIABLE=T,gw;NOMESH;"; + rval = mb.load_file(example_eul, &set, read_opts.c_str()); + CHECK_ERR(rval); // Write variables T and gw std::string write_opts; write_opts = std::string(";;VARIABLE=T,gw;DEBUG_IO=0"); Repository URL: https://bitbucket.org/fathomteam/moab/ -- This is a commit notification from bitbucket.org. You are receiving this because you have the service enabled, addressing the recipient of this email.
participants (1)
commits-noreply@bitbucket.org
